Development PHP/MySQL: No easy way to move row between tables?
Discussion in 'Software' started by jezmck, 6 Nov 2006.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    I don't think there is, but don't want to waste my time coding it.
    (I can't use anything third party atm)
  2. DougEdey
    5 Jul 2005
    How do you mean? Just moving a row across should take a few queries (or one if you exceptionally lazy)
    Code:
    LOCK TABLE src_table; INSERT INTO `dest_table` (c1, c2, c3) SELECT f1, f2, f3 FROM `src_table` WHERE condition; DELETE FROM `src_table` WHERE condition; UNLOCK TABLE src_table;
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    the problem is that these records have about 30 fields, so writing it all out would be a real pain.
    the tables are identical, so yes this is ought to be solved by having a status field, but it's out of my hands.
  4. DougEdey
    5 Jul 2005
    try
    Code:
    INSERT INTO `dest` SELECT * FROM `source`
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    blimey, never expected that to work!
    unfortunately, I don't think I can use this as there may be clashes with unique IDs. :(
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    I was going to use something along the lines of
    PHP:
    $get mysql_query("SELECT * FROM `source` WHERE ...");
    $got mysql_fetch_assoc($get);
    $qry "INSERT INTO `dest` ('".join("', '"array_keys($got))
    "') VALUES (".join(", "$got).")";
    but this doesn't allow me to alter/omit any values, and is therefore no better than your idea!
    Perhaps if I make my own join() style function with a foreach($a as $k => $v) {}
    Any other ideas?
  7. DougEdey
    5 Jul 2005
    surely implode() would be better?
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    join is just an alias of implode, I just prefer the word.
  9. DougEdey
    5 Jul 2005
    foreach should do you, or even a for loop, will make it easier to jump the requested values
