It can be done, they do it in phpbb forums i think. Anywho my question is if my entire website is gonna be PHP how can I make it so that if i edit my index (Example: A menu bar) it will change it auto maticcly on all my other ones (reviews.php articles.php guides.php ect.)
not sure if i'm totally understanding the way you phrased the question, but it seems the simple answer is to get them all from the same source. i presume you're thinking of something like: PHP: include("header.html"); //content goes here include("footer.html"); there are of course much nicer ways to make CMSs Alaric.
that would be one way of doing it... I'm slightly concerned at the simplicity of the question - you can't have done any php before if you're asking this gl Alaric.
I've used it a little and starting to get the hang of it so im doing my entire website in php and just wanted to speed things up.
Ok, this is just giving me greif, can someone make this script work for me? Go to my index http://drotain.dyndns.org/modsource/index.php and steal the source to use. then go to http://drotain.dyndns.org/modsource/menu.php For the menu when you are done just upload it somewhere or email to death_star_the_first [at] hotmail [dot] com if you could do this i would be forever gratfull and not worthy
You'll have to save the files as .txt files if you want someone to view the source code (I could be wrong, I'm new at PHP as well) save the files as "source-[filename].txt" or something like that, then upload it, let someone take a look and help you out, then take them down again. I'd be glad to help once I can access the code.
If you want to show people source code, you can use a page like this: PHP: <?php // Source Code Viewing Script v1.5 by Hwulex // 14/01/2003 // Xaprief.com echo "<html>\n<head>\n\t<title>Source Code Viewer</title>\n</head>\n<body> \n<form name=\"viewsource\" method=\"GET\" action=\"$_SERVER[PHP_SELF]\">\n<select name=\"source\">"; $path="./"; $types = array('php','css','js','html'); $handle = opendir($path); while (false !== ($file = readdir($handle))) { if ($file != "." && $file != "..") { foreach ($types as $current) { if ((strtolower(end(explode(".",$file)))) == $current) { if ($file==$_GET[source]) $selected="selected"; else $selected=""; echo"\n\t<option value=\"$file\" $selected>$file</option>"; } # current } # for each } # file } # while closedir($handle); echo "\n</select>\n<input type=\"submit\" name=\"submit\" value=\"Go\">\n<br><br>\n\n"; if ($_GET[source]) show_source("$_GET[source]"); echo "\n\n</body>\n</html>\n"; ?> Maybe not the tidiest thing ever, but does the job. Save as a php file and upload to your space. Remember to (a) password protect it or (b) delete it when not required. It will allow people to view the full source if every type of file specified in the $types array.
http://www.uploadit.org/files/151003-source.txt Hope that works... if not I can post it. Get images if you want from http://drotain.dyndns.org/modsource/images/
