Development PHP Working with seconds...
Discussion in 'Software' started by nry, 24 May 2009.
  1. nry
    nry Minimodder
    1 Nov 2006
    Basically got a variable $seconds, which holds a number of seconds up to 2 months
    Making some code to calculate the number of sec, mins, hours, days, weeks and months are in this variable
    So far I have this:
    PHP:
            $days intval(intval($seconds) / 86400);
    //Calculate the hours
    $hours intval(intval($seconds 3600), 3600);
    //Calculate the miniutes
    $minutes bcmod((intval($seconds) / 60),60);
    //Calculate the seconds
    $seconds bcmod(intval($seconds),60);
    Just the hours don't work.
    Not got past days yet either.
    Any help would be brilliant :D
  2. Firehed
    15 Feb 2004
    Try $hours = floor($seconds/3600); It looks like you're converting a valid value into base 3600, which is pretty much impossible (we don't have sufficient character sets to even represent that) and in any case will not bring the desired result.
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    Code:
    $hourdiff = "-3"; // difference in hours between the web servers time and your time
    $disp = date("l, d F Y h:i a",time() + ($hourdiff * 3600));
    echo $disp;
    you can use something simple like this if you wanted to display the time and date.. output would look like this
    Sunday, 24 May 2009 06:31 pm
    * just re-read.. this is more along what you wanted
    Code:
    $s = 200000; // number of seconds set
      $d = intval($s/86400);
      $h = intval($s/3600);
      $m = intval($s/60);
    echo $d."d ". $h ."h ". $m ."m ". $s."s";
    output for 20,000 seconds
    2d 55h 3333m 200000s
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    That would output the number of seconds converted to days, then converted to hours, then minutes, then seconds. He wants to convert it as a whole.
    I haven't tested this, but you should be able to use the mod operator to find the remaining number of seconds after dividing to get days, hours etc:
    PHP:
     // Divide by seconds in a week
    $weeks floor($totalSeconds 604800);
    // Get remainder after week division, divide by seconds in a day
    $days floor(($totalSeconds 604800) / 86400);
    // Get remainder after day division, divide by seconds in an hour
    $hours floor(($totalSeconds 86400) / 3600);
    // Get remainder after hour division, divide by seconds in a minute
    $minutes floor(($totalSeconds 3600) / 60);
    // Get remainder after division by minutes
    $seconds $totalSeconds 60;
    echo
    "$weeks weeks, $days days, $hours hours, $minutes minutes and $seconds seconds.";
    Should be easy to extend to months, years etc if you want.
    Edit: tested, works fine.
  5. thehippoz
    19 Dec 2008
    :duh: thanks hit.. that'll work- I was thinking- oh nm lol that's what he wants
  6. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Why? PHP found out timestamps for this:
    Code:
    $timestamp = 20000000;
    echo date('\D\a\y: d \M\o\n\t\h m \Y\e\a\r Y H:i:s', $timestamp);
  7. thehippoz
    19 Dec 2008
    yeah was thinking that too whizz when first read it.. but it looks like he needs the values put into strings for whatever he's working on
  8. BlackWhizz
    17 Jul 2008
    Thats what the date function actualy does!
    The only thing is that you need to escape the first parameter because some parts is text.
