Development phpbb plus or coppermine (for images & forum)?
Discussion in 'Software' started by MiT, 2 Jan 2007.
  1. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    Hi guys/gals,
    Just a quick question what would you recommend is better at hosting pictures and a forum Copermine + phpbb intergrated or phpbb plus on its own (which uses phpbb as backbone with extra mods attached to it)?
    I have never used coppermine of phpbb plus, so all your comments are welcomed.
    Thanks guys.
  2. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    How about SMF and something like SMF Gallery
    I h8 PHPBB
  3. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    i love smf! i reckon smf one would be better! personally!
  4. MiT
    18 May 2005
    Will have to look into SMF. Had a look at the screen shots, but was wondering if you had links to a web site where i can see it in full use. got any links??
    Cheers
  5. simon w
    simon w What's a Dremel?
    3 Nov 2003
    How about the SMF forum, www.simplemachines.org/community/ ;)
  6. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    I've used phpBB with coppermine, both integrated. It works well, as users can easily flip between the two and everything runs off of the same DB. But if you do go this route, you'd want to create your own theme, or adapt a current one, to integrate the two better.
  7. MiT
    18 May 2005
    I understand what you mean.
