Quick question I'm going to be using a GTX 460 as my main card and a GTX 9800 as PhysX card. I can't see any probs with it. What do you guys think, worth while combination? Thanks in advance
Considering that PhyX hasn't moved on any since it was last reviewed (or at least very little), the go-to PhyX card at the time was the GTS 250 (Aka; 9800GTX+), so it should be fine! Just plug it in and go, extra GPU horsepower doesn't really help with PhyX, just more shaders and a higher shader clock. So you could always fiddle with the frequencies in the thing if it's not fast enough.
It should work fine, presuming you have enough power connectors etc. The 9800 is possibly a bit light for physx, but I'd expect it to be beneficial overall ...
That was pretty much my thinking, I just needed a second opinion.. I'm not a mad gamer. I just thinking about using it for the simple reason that I've got it.
