Cooling Pi-Thon tube clamps
Discussion in 'Hardware' started by d0z, 9 Apr 2005.
  1. d0z
    d0z Minimodder
    1 Apr 2005
    I was just lookin at Pi-Thon and I was wondering which type of clamp i'd need in my WC system? the hoselocks or the hexlocks?
    Is there any one in the UK who sells these?
  2. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    it looks like any with the right diameter would work.
    I need to get some of those for my rig.
  3. Nexxo
    23 Oct 2001
    Yup; it doesn't matter what shape/type they are, as long as they are the correct diameter for your tube/barb.
    There are no resellers in the UK. You'll have to order them from the US, unfortunately.
  4. Wang
    Wang What's a Dremel?
    9 Mar 2005
    Do these come into contact with the liquid? They are super-bling... but they are Anodised Alu.
  5. Firehed
    15 Feb 2004
    Well if they're anodized, you wouldn't need to worry about galvanic corrosion.
  6. uwannabigmak
    30 Dec 2004
    i think theyre designed to replace hose clamps... no contact with water (unless it spills, and then the hose clamps would be the least of your worries)
  7. Nexxo
    23 Oct 2001
    As uwannabigmak says: they do not come into contact with water. They clamp around the outside of the tube and barb.
  8. XUntitled
    XUntitled What's a Dremel?
    6 Sep 2004
    Nexxo how much did you pay for yours? I was looking at some of the distributors sites and came back with $16.95 over here, and similar prices on the other sites. Did you get them any cheaper or no? I'm seriously considering buying some, but anything over a few dollars each just seems 'just not worth it' when i'd need 8-12 of them.
  9. Nexxo
    23 Oct 2001
    That was about what I paid for them. I think you can order them cheapest from Pi-Thon themselves, but they're still pricey... Quality kit costs.
  10. Firehed
    15 Feb 2004
    Modding ain't cheap!
  11. uwannabigmak
    30 Dec 2004
    does the ID matter at all? it lists the ID, but what matters is OD, right?
  12. XUntitled
    6 Sep 2004
    Yeah.. you can say that again Firehed. I'd be willing to pay $5 each, but $15 per just seems a little bit out there to do your hole system with them. I mean, spending $100-$150 on hose clamps when I have other hardware upgrades that I needs just seems to be money spent in the wrong place. But they are sweet as hell.
    And yeah uwannabigmak, make sure that they'll fit over the hose while its over the barb. Make sure that the min. compression will be far enough down to put pressure on them to make the seal to. But it seems like for our water cooling purpuses your looking at mainly the Vacuum type ones, which only offers 1 type in 1/2 inch ID and 1 type in 3/8 inch ID.
  13. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Have a lok at the table onthe pi-thon site, it explains the measurements well.
