Modding pics of me cutting up a hdd (not uber big anymore)
Discussion in 'Modding' started by modz-a-lot, 1 Jun 2004.
  1. modz-a-lot
    modz-a-lot What's a Dremel?
    28 May 2004
    well, i thought i'd try cutting a window in my hdd... (wd 200.) anyways, i've now made only about an inch cut and have used 3 dremel cutoff wheels. The stuff is way too thick for a nibbler, i've tried the drill bit attachment too. Still not making too much progress with the cutting. Any ideas on how to cut it?
  2. Jedi
    Jedi What's a Dremel?
    16 May 2004
    jigsaw should probably do it, or maybe an angle grinder ;)
  3. BjD
    BjD What's a Dremel?
    10 Apr 2003
    Yup used a jigsaw on mine, perfect for the job. Just be careful how you hold it down, i clamped mine a little too hard in the vice...still fits tho.
  4. modz-a-lot
    28 May 2004
    too bad i dont have a jigsaw :wallbash: and i think an angle grinder is a little big :D
  5. BjD
    10 Apr 2003
    Possibly keep it retro and use a junior hacksaw with a fine toothed blade? Might have issues getting it in there (ohh err) depending on where you're cutting.
  6. modz-a-lot
    28 May 2004
    i'll try that! thx
  7. woodshop
    woodshop UnSeenly
    14 Oct 2003
    oxygen acetylene cutting torch :D :D
  8. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    everybodys got one of those
  9. woodshop
    woodshop UnSeenly
    14 Oct 2003
    I do don't you? I really need a plasma cutter though. thoses tanks ar heavy.
  10. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    ok then lets all just burn ourselves wtuh a random array or cutting torchs's (sighs) good times
  11. modz-a-lot
    28 May 2004
    once i bought a $50 oxy acetelyne torch. my mom made me return it in fear that i would burn the house down :waah: i've always wanted a plasma cutter...but i did eventually get it cut with a hacksaw and about 20 fiber cutoff wheels :D i'll post pics friday...maybe earlier...i have finals next week so i'll be busy
  12. modz-a-lot
    28 May 2004
    got some photos of the progress on my hdd window
    i used about 6 cutoff wheels (for what the hacksaw couldn't get)
    here is my disassembled and partially cut hdd window.
    OOOH....shiny
    cutting pattern outlined
    used rubber pieces to prevent the clamp from ruining the seal and shape of the "lid"
    cutoff wheels before cutting and my dremel
    started using hacksaw
    those nerds @ western digital use 2 layers of metal :wallbash:
    what's left of my once very big cutoff wheels. i just need to cut out the corners and file/sand now......sry for the rediculously large images....too lazy to resize them...i gotta figure out how to make my digital cam take low quality pics
  13. Nexxo
    23 Oct 2001
    OK, first: Please resize your pics!
    Next, I hope you don't plan on doing anything useful with that HDD. Now you've opened it, it's "display purposes only"...
  14. Renko
    Renko What's a Dremel?
    19 Feb 2002
    wish they would put tutorials on using dig cameras on the labels instead of useless manufacturer data :duh:
    perhaps there's a reason they use 2 layers of metal? :confused:
    edit: that's 8.8 MEG! of images and for what??????! :wallbash: :wallbash:
  15. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    ADSL feeling like a 56kbps line connection at a bad time. Aarggh
    Shouldn't the rest of your hardrive suppose to be in the bathroom with a plastic wrap covering the exposed areas?
  16. modz-a-lot
    28 May 2004
    lol, i'll figure out my dig cam later. i'll resize them in pshop in about an hour (maybe later). you'll see i'm a big procrastinater.
    i know the hdd will prob only last a week (maybe less)but i dont care. it was an old 20gig.
  17. Mecha_Mindslayer
    Mecha_Mindslayer Banned
    23 May 2004
    please resize (or one of the mods will do it :D)
  18. modz-a-lot
    28 May 2004
    i said uber big
    EDIT: i finally got to resizing the images (2 hours after i originally posted them)
    sorry for the inconvenience, especially the 56k'ers. I gotta find out how to take low res pics with my cam. also, anyone know of a better place to put the images. right now i'm using angelfire (which doesnt allow hotlinking so i have to use anonymizer)
  19. modz-a-lot
    28 May 2004
    2 layers of metal = magnetic shielding-or-pain in the @$$
  20. Mecha_Mindslayer
    23 May 2004
