Motherboards Picture removal from start up sequence
Discussion in 'Tech Support' started by t4n6o, 1 Jan 2019.
  1. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    Not sure what section this would come under if bios or motherboard.
    When I load up my old PC usually where u see the motherboard logo or start up image, there is a picture of me and my daughter on there, and since I am getting rid of pc (selling to a mate) I want to remove this.
    How would I manage this?
  2. adidan
    adidan Avatar now in stock for xmas 2019
    25 Mar 2009
    How did you get it there?
  3. David
    David RIP Tel
    7 Apr 2009
    I remember some boards allowed you to upload your own image in the splash screen - pretty sure the removal process is via the BIOS, or through some app that was released with the board.
    OP, have checked out the board's support page?
    t4n6o likes this.
  4. adidan
    25 Mar 2009
    I'd never even heard of that, always assumed the logo was either on or off.
    TIL.
  5. t4n6o
    16 Aug 2011
    That's right David, I just can't remember how I did it as it was way back in 2009 ish lol. I'm currently looking on the Asus website (not to much avail) but have another port of try to test out yet, but if it was via bios how would I go about this?
    Once again TIA
  6. David
    David RIP Tel
    7 Apr 2009
    IIRC, Asus had an app called MyLogo but I don;t know it your board pre-dates that app, and you may have to do it manually by entering the BIOS - I think some allowed you to upload from a USB stick, much like you can with bios updates.
    TheMadDutchDude and t4n6o like this.
  7. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    Yup David's nailed it.
    Chances are you will have set it through a windows app from your motherboard manufacturer. Or as he said a bootable USB.
    Only thing is the app used may not work with 10...you don't wanna have to install 7 just to remove a boot up logo :(
    t4n6o likes this.
  8. t4n6o
    16 Aug 2011
    Looks like my freshly installed windows 10 system wont allow me to use the mobo disc :wallbash::wallbash::wallbash::wallbash:.
    Didn't want to have to re install 7 to do this and then 10, but never mind i guess..... looks like i have a busy few days lol
  9. modd1uk
    4 Sep 2006
    Don't use the mobo disc fella. Just visit the manufacturers site and download any drivers you feel are necessary...and the all important utility to remove that splash screen logo.
    If it's an older mobo you'll find the drivers provided during the 10 installation will be more than fine...and probably a lot newer than the ones on the motherboard manufacturers website .
    If it were me I'd install 10 and then find whatever utility is needed to remove the splash screen logo on the mobo site ..if that didn't work I'd probably just do a quick install of 7 just to remove it..then flatten the SSD and install 10.
    t4n6o likes this.
  10. t4n6o
    16 Aug 2011
    Tried that, however the manufacturers website didn't have any utility downloads for win 10
    Pardon my ignorance, and stupidity after a night on the sauce lol, after a quick install of 7 and it gets removed (hopefully) and flatten the SSD and install 10, i presume you mean install 7 remove image and wipe SSD and reinstall windows 10 again?
  11. modd1uk
    4 Sep 2006
    Yup that's exactly what I mean. :)
    And regarding the site ..ignore looking for windows 10 downloads, if there are any 8 drivers they may work..although as I said the ones provided by windows may well be sufficient.
    Look under windows 7 downloads for the utility...you won't know if it works until you download it and try it.
    Past experience for me is mixed, I've had some old utilities designed for 7 work perfectly on 10..others refused.
    t4n6o likes this.
  12. adidan
    25 Mar 2009
    Had a quick look about, do any of the AI Suites run on your board?
    I think there are win10 versions out there and I believe they include the logo jiggerypokery.
  13. theshadow2001
    3 May 2012
    Can you reflash the bios rather than messing about with desktop software?
  14. modd1uk
    4 Sep 2006
    It may work...sometimes the boot image doesn't get overwritten (mainly OEM boards).
  15. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    typically I've always done this with a USB bootable with the bios image and flasher.exe (name may vary lol). I know one of the Intel and MSI apps its a switch on flashing the BIOS image to reset the image so you do the usual bios flash (with same version you currently have or a newer one if you like) and you just figure out what the command line switch is for it. What model board is it?
  16. t4n6o
    16 Aug 2011
    Forgot to update yesterday as a mate wanted to go race on PC2.
    Got it removed and put it back to stock. Unfortunately I couldn't find an AI suite for windows 10 for this board (probably due to its age), so had to install windows 7 to fix the issue. so its back to stock and now just need to install windows 10 onto the machine.
    Thanks to everyones suggestions and ideas
    modd1uk likes this.
  17. adidan
    25 Mar 2009
    Sounded like a bit of a faff for you, glad it's sorted though :thumb:
  18. t4n6o
    16 Aug 2011
    Faff...Fun... its all good, its been a while since i did it so maybe its a refresher course for myself lol :grin::grin::grin:
    adidan likes this.
  19. modd1uk
    4 Sep 2006
    Get a fresh install of 10 on it now then and job done :D.
  20. t4n6o
    16 Aug 2011
    Exactly, then its sold and I have extra funds towards desk, chair, monitor/s and VR
