Not sure if this should go here or in Tech-Talk, but I'll take my chances here. I want to get one of these switches to work as a power button for my PC: https://www.elfa.se/elfa3~eu_en/elfa/init.do?item=35-074-37&toc=20538 What exactly would I need to make it work?
As long as it's a momentary switch it'll work. Other than that all you need is the lead off an old switch to run to the mobo.
It will work. I don't see any advantages over a standard switch other than they tend to be sealed and more robust. Other than that just wire it up as normal.
Ive tried a capacitance switch before, it did not work as a standard momentary switch, not a piezo type, in the end i cba to work it out, i think i needed extra voltage input and stuff. So your right to querey it. I got my meter accross it etc, couldnt work the little bugger out, may of needed extra circuitry, found it easier to convert a momentary switch to a latching switch with extra circuitry, but for the hell of me, couldnt work out the capacitance switch, paid about £20 for it aswell.
