Electronics Pilot Toggle switch for a Power Switch, is it possible
Discussion in 'Modding' started by quibbage, 5 Jun 2007.
  1. quibbage
    quibbage What's a Dremel?
    4 Jun 2007
    First of all im a complete noob at anything electrical(even though it looks interesting) so keep that in mind while yourre reading this so anyways...
    I was thinking of using this
    as my power switch in a mod im working on but im curious whether it will work. Any ideas?
  2. the fodder
    the fodder What's a Dremel?
    26 Jun 2006
    power switches are off in their resting state and only connected when you push the button, that switch looks like one direction is on the other is off like a Light switch. You could use it as your power if you just flick it on then back off really quickly. I say might because you might also just keep rebooting your system. one Lan I saw a guy starting his computer by shorting out two bare wires. REAL GHETTO
  3. capnPedro
    11 Apr 2007
    Yeah it works as long as you flip it on/off. Mnpctech sells a modified version.
    Bah! Real men lick their fingers and short the mobo jumpers. (Probably too high impedance, use a screwdriver)
  4. quibbage
    4 Jun 2007
    ya but im short on cash and the modified one is double that of the normal one, is their any way to modify one to make it work just as good as the ones from mnpctech?
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Yes, add a 555 monostable to give a short pulse and then do nothing. But you've still eventually got to turn the switch off manually.
  6. elctroJunky
    elctroJunky What's a Dremel?
    9 Jan 2006
    You could also make the switch on procedure with two buttons...
    Use the pilot toggle switch to enable another button that works just like a normal power switch...
    On the other hand you've got a few seconds time before you need to turn the power switch off again, so you might just do that.
  7. quibbage
    4 Jun 2007
    Do you now where i can buy one(a 555 monostable) or if id be able to build one??? might be fun to try ;)
  8. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Buy it, rip out the guts of the switch, replace with a momentary switch something like this:
    with the button sticking out from where the lever originally sat so the cover still, emm, covers it
  9. quibbage
    4 Jun 2007
    That works but...
    Great idea!! ill probably do that... but the actual toggle switch still looked pretty cool though, a well :waah:
    Thanx for the help!!
  10. THEkorean
    THEkorean 42
    10 Jun 2005
    just got find a momentary toggle switch and buy a cover for it, ive seen those red toggle covers on the internet somewhere
  11. quibbage
    4 Jun 2007
    I said in an earlier post that i cant afford to spend that much on 1 switch right now, my dad wont let me get a summer job here, no clue why though... so im back to modding the toggle with a momentary
  12. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    If you put your finger on hard enough to let the pins pierce your finger it will turn on. It hurts, though. (Believe me, i tried. Not on purpose, though)
  13. quibbage
    4 Jun 2007
    Thanx for the tip wouldnt have thought that would happen :worried:
  14. devenfore
    devenfore LANCandy
    8 Jul 2003
  15. quibbage
    4 Jun 2007
    Thanx you just made my life 5x easier :D
