Graphics pink cs:source?
Discussion in 'Hardware' started by webbyman, 9 Jun 2005.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
    the maps in counter strike source seems to go pinky and black in some places sometimes, anyone else had this problem? could it be heat? fubared ram? fubard driver or fubard gfx card?
    personally i think it's the ****ed up drivers as cs:s seems to just freeze then continue, this never happened on my last install of cs:s ?
    also anyone know the 'vilendiadoirj' universal drivers or whom ever they are called? *the part creators of hl-2* optimised drivers? i wouldn't mind trying them last time for some reason it went ****ed up so i have installed the crappy upto date nvidia ones :duh:
    also it pi**s me off when objects don't load properly in cs:s and on top of that i get loads of runtime errors where memory can't be read :grr:
  2. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    do you mean pink and black checkers for the textures?
    if so thats what a map looks like when its missing all the textures.
  3. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Its happened to me a few times i think from alt tabbing, but in my case some objects like crates and barrels would turn a solid black color.
  4. webbyman
    webbyman Hax.
    7 Oct 2004
    in alt tabbing when loading levels you just get black objects...
    but i'v had pinky stuff in the cs:s stress test
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Just means some of the textures are missing. Try re-installing the game, or just put up with it ;)
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    i think im going to reinstall it :idea:
    since i have the hl-2 disc with me now
  7. Firehed
    15 Feb 2004
    If it's an official map, something is wrong. If it's a custom map, it's someone who sucked at designing and left out the textures (or the server failed to give you any custom textures)
  8. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    HL2 does that sometimes. A texture may not load correctly, or you may be missing a texture file somewhere. Switching apps a lot does that to me when I am playing. I've had my hostie models suddenly look like explosions of random polygons after I came back from an alt+tab.
  9. Froggy
    10 Jun 2003
    Hmm wonder if there is a way to take advantage of this and make the map have invisible walls.....
  10. mobius9
    mobius9 Minimodder
    4 May 2004
    thats not even the worst. heres from castleball:
    its pretty apparent to me that there are some sort of graphic issues in source. This has only happened to me twice. I get a lot of pink/black randomly too, but then again I'm running a nvidia and you know valve's history with ati as of late.
  11. webbyman
    webbyman Hax.
    7 Oct 2004
    yep, i think some people do
