Pink Supergirl Linux Box (June, 2006)
Discussion in 'Project Logs' started by Shannon, 27 Jun 2006.
  1. Shannon
    Shannon What's a Dremel?
    1 Jan 2006
    Fresh coat of pink on my DVD tray
  2. tkh
    tkh Minimodder
    1 Mar 2006
    That cant be good for the DVD drive, I would have dismantled the thing before spraying it.
  3. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    Pink... is diferent, add some accents on another color and it will loook better.... stilll is nice...goo gooo goooo....
  4. Shannon
    1 Jan 2006
    well, I taped it pretty good, so I think it's okay.
    here's the second coat on my case:
    the lighting's different though, it's cloudier today.
  5. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Nice job on the paint, Shannon. Is there a reason you're a bit scared of hacking? A dremel is indeed your friend... :D
    Oh, and about the 'being a girl' thing...be careful, don't feed the locals around here ;)
  6. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    What pain did you use? Just regular can of spray paint from Hardware shop?
  7. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    i dunno i mean ....... ...... ..... ok no clouds ;)
    pink wouldnt exactly be my choice of colour, but if thats what u want ;) interesting to see how this turns out, btw - is there a computer, or is it just a dvd drive :worried:
  8. Shannon
    1 Jan 2006
    I'm not scared of hacking, I just don't really want to cut things. Also, I'm trying to use just things I already have. Yes, I already had the spray paint. I did use a special primer for the plastic which has worked perfectly for things like the mouse in the past.
    My sister is over here now so she's going to help me paint on the S or make a stencil for it, we haven't decided yet. I even plan to paint a faux case badge with the S in the case badge spot.
    There will be a computer in it, the computer parts just aren't in there yet because I'm painting it. I fully intend on having pictures taken of myself while I am assembling it. :)
  9. Shannon
    1 Jan 2006
    Okay, here's my younger sister drawing a stencil for me. I brought out a shirt for her to use as a guide.
    here it is finished, and there I am trying to cut it out
    [​IMG] [​IMG]
    I started thinking about it too much and confused myself about where I needed to cut out so I had to stop and take a break
  10. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
    looking good
    what are the specs of the components you will be using?
  11. Denied
    Denied What's a Dremel?
    28 Oct 2005
    Looking good so far... I like that the colour scheme matches your nails... it's all in the attention to detail!
  12. foundsoul
    foundsoul What's a Dremel?
    24 Aug 2004
    nice job keep it up. I like the ur photo as a angel it hott.
  13. ch424
    ch424 Design Warrior
    26 May 2004
    Ha! Reminds me of tempgrrrl
    Shannon, no pink computer is complete without UV - try and find a pink version of this stuff...
    ch424
  14. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    haha! That is actually quite funny.
  15. Shannon
    1 Jan 2006
    okay, that tempgrrl thing is a little disturbing. Don't feed the locals. I see.
    The components are nothing fancy, just stuff that I scrapped from other machines. I've got an Athlon XP 2800+, 512mb RAM, a random socket A mobo, a power supply which is I believe 450 watt, and I have a couple of choices for video and sound cards so I haven't quite decided which I'm going to use. I think I'll be using an older 80gb hard drive. I've got a Netgear wireless card, but I don't know if I'll be able to find drivers for it for linux.
  16. Hiren
    Hiren mind control Moderator
    15 May 2002
    That stencil came out pretty nice.
  17. Krikkit
    21 Jan 2003
    :hehe: Classic.
    PC's looking good, perhaps taking teh DVD drive apart would've been a good plan though, you might've got the laser all painted up. They're not that hard to take apart, all you need is a screwdriver.
    Nice stencil, it'll be interesting to see how it turned out.
  18. yahooadam
    21 Mar 2006
    the computer or shannon ? :D
    some pink UV sleeving would work :) if there is a window in the case :) :duh:
  19. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    Which card is it? I think Netgear have some linux drivers on their site for download. Any idea which *nix distro you'll be using?
    Nice to see something a bit girlier on here for a change ;)
  20. Jipa
    5 Feb 2004
    Didn't she already say she's gonna use SUSE? Atleast I think so.
    I better buy myself a new computer as 2800+ is "just stuff" :(
