A/V pink videos?
Discussion in 'Hardware' started by wafflesomd, 19 Feb 2006.
  1. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    so for some reason all of my video's i try to play have a pink tint to them. anyone know why?
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Are you sure your player hasn't got a colour correcter turned on?
    In WMP for example you and go to "enhancements" and then "video settings" and change it from there.
    What video player are you using?
  3. Matkubicki
    Matkubicki What's a Dremel?
    18 Jan 2005
    when you say tint do you mean totally pink with a just visible outline of the action behind them? If so then i have that and it only happens with WMV files for me.
    It isnt the colour correction in my case i know that for sure
  4. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I had this happen to me once too, but a reboot solved it. Never did understand what was causing it tho.
  5. paul_s57
    paul_s57 What's a Dremel?
    23 Dec 2005
    This happened to me once too, all my video files / dvd's became quite pink, was quite odd, i found that updating the graphics driver seemed to fix it.
    I still havn't worked out what caused them to turn pink in the first place.
