hi, somebody know where i can find the little pin that goes on the wire ?? you know the pin that you put in the molex ...? I don't think they got that at radioshack...
Male Molex Pin Contacts is what you want if you're plugging into the molex on your PSU, if you want to get the same pins as in the molex on your PSU you need Female Molex Pin Contacts. A quick search should find some suppliers in the us, if all else fails you might want to try the molex website, not sure but you might be able to order direct.
Try the online mod shops. They sell molex connectors either male/female housing including the 'pins' (=crimp terminals).
