Modding Pipes, Discs, and Chaos - Scratch Build
Discussion in 'Modding' started by YellowHarold, 27 Feb 2020.
  1. YellowHarold
    YellowHarold What's a Dremel?
    26 Feb 2020
    Greetings people.
    I am Harold, and this is a showcase of my scratch build.
    The build is made from a motherboard tray from an old case, and mostly random parts that I found laying around my workshop. (Yeah, I hoard stuff, don't judge)
    In this thread, I will try to go over how my computer is put together, and some of the reasoning behind my crazy choices.
    The specs of my system:
    MB: ASUS Prime X570 pro
    CPU: AMD Ryzen 7 3700X - Water cooled
    GPU 1: Radeon RX 5700XT - Water cooled
    GPU 2: Radeon R9 390 - Air cooled
    RAM: Corsair Vengeance LPX 16GB at 3600MHz
    Nvme: Corsair Force MP600 1TB PCIe 4.0
    Other drives: 1x 250GB SSD, 2x 500GB HDD, 1x 750GB HDD, 1x 1TB HDD
    PSU: Corsair TX850M
    Rad: Alphacool 3x120mm
    Pump: Magicool MC-DCP450
    CPU and GPU blocks are from EK water blocks
    Tubing is 10mm OD chrome plated copper.
    Fittings are G1/4" - 10mm brass compression fittings.
    The PSU is mounted to a bracket made from translucent acrylic, and has a hydro-dipped acrylic plate on top, to shield it from potential leaks from the water cooling above it.
    Above the PSU sits the two GPUs. Clearing the wider R9 390 required some extra fittings, but it worked out.
    The CPU block from EK looks super nice, and is well contrasted by the super old 90 degree fitting that I had to use as I ran out of new ones.
    The harddrives are mounted to a custom bracket, along with a large fan that keeps them cool. (Not that they get very hot though)
    I am very happy with the backplate paintjob of a bomb dropping.
    The coolant is EK cryofuel, solid cloud white. I made sure to add a drain port and a fill port at the highest and lowest points of the loop.
    The entire computer is lit with addressable LED strips. The acrylic back panel is for mounting of the rad and pump, as well for supporting the main structure, by resting on the base.
    The base is made from a large, ventilated brake disc (possibly from a van?) and everything is bolted to that.
    The ventilation holes in the brake disc make for some cool lighting effects.
    Wires, pipes, weird shapes, and rainbow puke lighting.
    I am pretty stoked with how this build turned out.
    I hope you enjoyed this peek at one of my crazy projects. Feel free to drop me a question or a comment if you want something explained better, or if you have any suggestions.
    PS. Join the Bit-Tech Discord server!
  2. AllXFrag
    AllXFrag What's a Dremel?
    20 Jul 2019
    Jank at its best. Love it ❤️
    YellowHarold likes this.
  3. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    The idea is good, it reminds me some works of "Mod by benq" but you should sleeve and try to hide all those cables as much as you can.
  4. Diletta Graziosi
    Diletta Graziosi What's a Dremel?
    27 Feb 2020
    too much confusion with the cable, and in my opinion the tubes are a bit to long, i mean, it look goood and junky in a nice way, but with some other work coulb be improved a lot!
  5. Cheapskate
    13 May 2007
    Jank...Yes. Allxfrag nailed it. It's NEAT! :D -but messy. My only issue is is you should've cleaned up that one crusty fitting over the cpu. :lol:
    As a fellow collector of random chunks of metal I have to warn you to get something under that brake disc. Even lacquered they have a habit of collecting moisture underneath and rusting. I'd also recommend Johnson's paste wax. -The foul stuff that is like a mix of ear wax and gasoline. One coat stops rust for decades.
    This setup is great for tweaking over time. You might have noticed we are finicky about cables here. You have lots of room to work on that and even add new stuff.
  6. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    White SATA cables. That's what's missing.
