Hi folks! This is the second build I'm documenting here, although I've hade a few more builds done the past years. This build is a collaboration between me and my friend GhazzyTV whom is a full time Path of Exile streamer. We also have the following brands aboard right now too: MSI - Suppling RX 5600XT, MSI MEG Z490 Unify and an Intel i7 10700K Kolink - Suppling a Kolink Observatory (Through the nordic distributor Trigono AB) Cablemod - Suppling GPU-riser (Through the nordic distributor Trigono AB) Superflower - Leadex III Gold A-RGB 850W (Through the nordic distributor Trigono AB) The build will be a done as a custom loop with a pirate theme around the pirate character in Path of Exile and the ghost-flame. We're trying to keep things really dark and light things up with "ghost-flame-like" lightning. I'll be uploading a few pictures soon, right now though I had to abort and go help my wife with dinner. Hahahaha
Ooh, I have totally forgot to update this build-logg! So, here comes som updates! Sponors: MSI, Kolink, Superflower and Cablemods! Kolink Observatory - The case to use Inspiration - Captain Hargraves from Path of Exile Superflower Leadex III ARGB 850W Gold PSU And some love from MSI in form of the MSI MEG Z490 Unify! Me and GhazzyTV talking about the build and stream, before all COVID-delays delayed the build with 4 months! Tearing of some sheetmetal from the case, stripping it! Toying with some acrylic for a new PSU shroud Testing the tubing, the case is just too damned small for my plans! So the front glass is extended by 12mm to increase air-intake to the radiator mounted on the front, with fans on the inside instead. The case isn't supposed to house a 360mm radiator, watercooling or anything like that. Not to say the veritcally mounted GPU. It was a pain to build in actually.
So we quickly moved over to the finished build. I had to change some plans on the way due to several factors. So the build became "simpler" than I had intended, but still I pretty good result I'd say. Me and GhazzyTV are happy though!
