Modding Pitbull by Darth Invader
Discussion in 'Modding' started by Darth Invader, 31 May 2007.
  1. Darth Invader
    Darth Invader What's a Dremel?
    31 May 2007
    Casemod used as firewall of my domestic net.
    Cut windows the hand, with the drawing of a pitbull on the two sides, covered by Chrome Molding.
    Painting interns blue UV, painting it expresses in the white;
    Baybus that controls the illumination interns (2 cold UV), back fan, back blower, strobo, all screws substituted by thumb screws
    hugs,
    Dart
  2. saltynay
    saltynay What's a Dremel?
    12 May 2007
    nice mod what did the original case look like???
  3. Darth Invader
    31 May 2007
    Thanks Slatynay...
    Since you asked... The case originally was this way: :worried:
    Hugs,
    Darth
  4. saltynay
    12 May 2007
    What's the spec for the inside?
  5. Darth Invader
    31 May 2007
    That computer is used as Firewall, because of this it need not much hardware.
    Celeron 333 + 256 ram + hd 1gb + AM Coyote Linux :cooldude:
    Hugs,
    Darth
