Planned site downtime this weekend
Discussion in 'Article Discussion' started by Tim S, 27 Mar 2008.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Pings and Tracert looked good, 30/31mS to both sites.
    I was having the same trouble in IE and FF, think I've cracked it reducing MTU from Vista default 1500 to 1430. Apparently Vista can't auto-adjust my MTU to suit as I'm un-pingable. Does that make any sense re your servers? :confused:
    Whatever, seems to work OK now. :)
  2. Glider
    Glider /dev/null
    2 Aug 2005
    I tought 1500 was standard (it surely is on Linux) but Windows uses an other calculation method so that 1500 on Linux is 14XX on Windows. Not sure tough.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    1500 is the maximum and common, but some servers transmit smaller packets. AOL use 1400 IIRC, at one time the BT network was using 1458 or some such figure.
  4. dom_
    dom_ --->
    4 Jan 2004
    I have a slight problem. Since the fix i keep having to sign in when i come back to the site. The box is ticked and all that, but it still wont auto sign in.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Try clearing the old cookies.
  6. DougEdey
    5 Jul 2005
    Dunno why but every time I view any thread or forum at the moment all the images refresh, even the ones that are cached
  7. Glider
    Glider /dev/null
    2 Aug 2005
    1500 certainly isn't the maximum... look at jumbo frames in switches...
  8. completemadness
    completemadness What's a Dremel?
    11 May 2007
    I think it depends on your ISP, auto adjust is supposed to deal with this, but i guess not in this case
    I believe my connection to BT is around 1450 or something, but i haven't looked at the modem in a long time
  9. dom_
    dom_ --->
    4 Jan 2004
    Done that but it has not helped.
Tags: Add Tags
