Build Advice Planning ahead - Part the 2nd
Discussion in 'Hardware' started by Jeff Hine, 14 Jul 2019.
  1. Jeff Hine
    Jeff Hine .
    8 May 2009
    Pretty much set on using ROG STRIX B450-F GAMING for my impending upgrade, but - probably overthinking - finding it worrying that there's no QVL for RAM support w/ Zen 2 CPU's...
    What danger would there be in taking the RAM QVL for Zen+ CPU's as 'gospel'...?
  2. Vault-Tec
    30 Aug 2015
    As I said in PM it is the same tech, only better. So yes, I would say you could apply the QVL from Zen 1000 and 2000 series and be OK.
    The reason B die is better, dude, is because it's well, better. I know with the 1000 and 2000 series it was very important to clock your ram to at least 3000mhz because Infinity Fabric runs at the RAM speed which made a big difference. Like, 20% over running 2133mhz RAM.
    I know that with Zen 2 they have increased the cache which apparently alleviates that problem but I have yet to see any concrete evidence. No one has tested it at slower RAM speeds, and I have a 16gb 2666 kit I wanted to use. If I find, however, that I have to buy RAM I will stay where I am at for now. Both rigs I have do what I want them to so it would be daft spunking money down what could be a expensive drain.
    Jeff Hine likes this.
  3. Jeff Hine
    Jeff Hine .
    8 May 2009
    Starting to feel like settling for R7 2700 on X470... & - funds allowing - either 32GB RAM (over 16GB) or 16GB RAM & m.2 system drive
  4. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    Why 32GB of RAM? Why m.2? How will you be taking advantage of these?
  5. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    My last upgrade was a 2700X, B450, 32GB of DDR4-3000, and a 1GB M.2 NVMe. It's pretty durn nippy, and 'cos I'm on a B450 board I can drop in a Zen 2 chip in a few years time for a cheap upgrade.
  6. Jeff Hine
    Jeff Hine .
    8 May 2009
    Currently have 32GB DDR3... and m.2 - why not? Seriously, it would free up the current SSD for use on Grandsons' PC that I'm making w/ i5-4690K I have now.
    Arboreal likes this.
  7. Osgeld
    Osgeld Active Member
    9 Jul 2019
    M2's current prices make them very attractive as well
  8. Jeff Hine
    Jeff Hine .
    8 May 2009
    m.2 may have to wait for another day.
  9. Mr_Mistoffelees
    Mr_Mistoffelees The Cat Lies Down on Broadway
    26 Aug 2014
    Unless you actually need more RAM, why not go for 16GB plus an nvme M2 drive?
  10. Jeff Hine
    Jeff Hine .
    8 May 2009
    That's the primo plan; just gotta see if funds stretch that far.
    Dunno I ever used the full 32GB I have, now... so 16GB makes sense.
    These two are definites... rest is still 'undecided'.
  11. GeorgeStorm
    16 Dec 2008
    You can always buy a single stick of 16gb with the option to add another in later if you need it. That's what I did with my current daily (but with 8gb sticks) and have yet to actually get another stick haha.
  12. adidan
    25 Mar 2009
    The max version of that board will be out soon, probably best to pick one of those up with the increased BIOS size.
  13. Jeff Hine
    Jeff Hine .
    8 May 2009
    X470... in Max?
    Will a single 16 perform any worse than two 8's (dual channel)...?
  14. adidan
    25 Mar 2009
  15. Anfield
    Anfield Well-Known Member
    15 Jan 2010
  16. Jeff Hine
    Jeff Hine .
    8 May 2009
    I'm working with £400 for CPU, 'board & RAM - my guess would be that the MAX would kill the (already tight) budget
  17. Gareth Halfacree
    4 Dec 2007
  18. adidan
    25 Mar 2009
    They're supposed to be replacing the current line up, aledgedly at the same price point.
  19. Jeff Hine
    Jeff Hine .
    8 May 2009
    Prob gonna stick to two 8GB & swap out to two 16's (much) later
  20. Jeff Hine
    Jeff Hine .
    8 May 2009
    Biggest fear...? RAM fail/incompatibility & no RMA 'cos I broke the seal on the 'packing'...
    ... and for 'fear', read 'simmering paranoia'.
