Build Advice Planning ahead - Part the 2nd
Discussion in 'Hardware' started by Jeff Hine, 14 Jul 2019.
  1. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Looking better, but posting it here will now jinx it... knowing my luck. :(
  2. adidan
    adidan Avatar now in stock for xmas 2019
    25 Mar 2009
    Out of interest, why did you settle on an X470 and not a B450? You started with a B450 and then the X470 became a definite?
  3. Jeff Hine
    8 May 2009
    Price... RoG Strix B450 is priced higher than MSI X470. Then again, I have certain criteria for a mainboard outside of CPU/RAM slots, like 5 jack Audio on rear I/O.
    This is why it takes me an age to finalise upgrades.
    EDIT:
    Many would even conclude that what I'm trying to do on my budget is impossible w/ new parts...
  4. Jeff Hine
    8 May 2009
    OK; I'm throwing it out there...
    £400 - read my signature & upgrade the CPU, motherboard, RAM (and add a "240/250GB" m.2, if the budget stretches). to Ryzen 2 or 3 levels - NEW parts only & guaranteed compatibility.
  5. Osgeld
    Osgeld Member
    9 Jul 2019
    I think its possible but you are going to have to be patient and watch sales like a hawk
    I did that took like 4 months but it gave me plenty of time to mod my case lol
  6. silk186
    silk186 Derp
    1 Dec 2014
    I strongly recommend an M.2 drive. I upgraded and notice an improvement in system usability. Even running large work documents with referencing software was significantly improved over SATA based SSD.
    I'm looking into upgrading from 16GB to 32GB as prices are coming down, but I'm not sure I really need it.
  7. Jeff Hine
    8 May 2009
    Errata:
    1. £400 to include all 3 (or 4) options... not just one (@silk186 :D)
    2. 16GB RAM, not 32GB
  8. Vault-Tec
    30 Aug 2015
    Do it whilst you can. Ram prices are so volatile.
  9. Jeff Hine
    8 May 2009
    I have a list - amongst many - with one factored in... we'll see how the budget works out.
  10. yuusou
    yuusou Well-Known Member
    5 Nov 2006
  11. Osgeld
    Osgeld Member
    9 Jul 2019
    The msi b450 boards are a decent choice just do not get too heavy handed with overclocking as there is only 1 vrm heatsink on the gaming + boards
    Mine has been very happy but I'm not maxing things out ( 8 core 4ghz 2700 at 1.3 volts)
    If I put it in what I call "asshole mode" 1.4 volts 4.3 something ghz its fine but everything gets toasty (for not a large gain)
  12. Jeff Hine
    8 May 2009
    Latest update, here... 'should' have money on Monday.
  13. silk186
    silk186 Derp
    1 Dec 2014
    I'm wondering if they will drop further. Prices in the used market have not really dropped in line with recent sales.
    RAM is something I'm happy to buy used.
  14. Jeff Hine
    8 May 2009
  15. Vault-Tec
    30 Aug 2015
    Second one doesn't work.
  16. adidan
    25 Mar 2009
    Just remove the ...? from the link to make it work :winking:
  17. Jeff Hine
    8 May 2009
  18. Vault-Tec
    30 Aug 2015
    First one for sure if you do anything other than gaming.
  19. yuusou
    5 Nov 2006
    If what you do is mostly gaming, which seems to be the case, the 3600 will be a better fit.
  20. Jeff Hine
    8 May 2009
    Thx... /pest mode
    Arboreal likes this.
