Build Advice Planning ahead - Part the 2nd
Discussion in 'Hardware' started by Jeff Hine, 14 Jul 2019.
  1. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    Or order the mobo and CPU from CCL, they'll update it for you.
  2. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    Already ordered & paid for, from elsewhere. Deleted previous message as I'm sure I have the 'bits' to effect a BIOS change prior to functional build being completed.
  3. Jeff Hine
    8 May 2009
  4. Jeff Hine
    8 May 2009
    Just noticed the extra ATX EPS socket for the CPU - lucky that OCZ supplied 2 cables for such purposes all those years ago when I bought my 750w unit.
    At some point in the future; Part the 3rd - custom water-cooling loop (not because I 'need to' either)
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I may be looking to sell my old watercooling parts soon, so keep an eye on the marketplace :p
  6. Jeff Hine
    8 May 2009
    I would... if I hadn't perma-banned myself from there for lacking the self-control to NOT take threads off-topic -- and by perma-banned, I mean asked for my access to the sub-forum to be removed.
    Bloody_Pete likes this.
  7. Vault-Tec
    30 Aug 2015
    Ack I threw a load away when I left my flat. I would have given it away just didn't have time. Full set of fittings in white (bits power) two rads etc. In fact no, make that three rads.
    I just don't have the space now man. Shame, but, it has stopped me from serial fiddling (fnarr).
  8. Jeff Hine
    8 May 2009
    Having failed to boot my X470 'board/Ryzen 5 3600 combo. - BIOS seems to be wrong for Zen 2 - it occurred to me that a 'board/CPU/RAM set-up may require a drive of some sort to even get to a BIOS screen - did I n00b it not having a drive connected...?
  9. Bloody_Pete
    11 Aug 2008
    Shouldn't do, just CPU, and RAM, some don't even need that! Any error codes?
  10. adidan
    adidan Avatar now in stock for xmas 2019
    25 Mar 2009
    PSU/mobo/cpu/gpu/ram.
    That's it.
    Some MSI boards with flashback only need a psu afaik.
  11. Jeff Hine
    8 May 2009
    Nah; just flat failed to boot - was half expecting it, anyway as I didn't get the 'board & CPU from the same place, let alone check what BIOS version the 'board had prior to ordering it.
  12. Jeff Hine
    8 May 2009
    Had exactly those...
    That's the 'Flash Harry' bit where a button is assigned to a select USB port & you just press the button & wait...
    Not the one I have :(
  13. adidan
    25 Mar 2009
    Yeah not sure why some do and some don't.
  14. Jeff Hine
    8 May 2009
    Availability of tech. at design stage of/target market for the 'board in question...?
  15. Bloody_Pete
    11 Aug 2008
    Premium features
  16. Jeff Hine
    8 May 2009
    ... targeting higher spenders.
  17. Jeff Hine
    8 May 2009
    Part the third will probably have to factor in a new case... having tried to make the best of (what turned out to be) a bad job, when I got a Liquid Freezer 240, I'm not entirely sure a rad. of any description will fit into my Antec P280.
    ... but that's a 'problem for another year'.
  18. Bloody_Pete
    11 Aug 2008
    Its the problem with golden oldies, they lack little details like offsetting the fan mounts to fit rads...
  19. Jeff Hine
    8 May 2009
    How ambitious would it be to use this - in a Define C - as a start for a first shot at a combined CPU/GPU loop...?
    EDIT:
    Can this be done cheaper than £380...?
  20. Bloody_Pete
    11 Aug 2008
    Yes, because I'm about to list more or less a full loop on the marketplace :p
    If memory serves the Define C should be fairly straight forward :) Looking at photos the only pain will be pump placement.
