Small Form Factor Planning to watercool a Shuttle SN41G
Discussion in 'Hardware' started by iddqd, 29 Nov 2007.
  1. iddqd
    iddqd Minimodder
    6 Feb 2006
    Small project I want to do. Yes, I searched, and the posts I found date back to '05 (and a recently resurrected post from last year). What I have is a Shuttle that my girlfriend uses for school stuff and light gaming (HL2 mainly). The problem is the dang thing overheats so easily. What I want to set up is a water cooling loop for the CPU.
    The kit I remember looking at is a Globalwin Silent Stream. I can't seem to find these in stock anywhere, does anyone have a link?
  2. iddqd
    iddqd Minimodder
    6 Feb 2006
    Bump?
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Custom loop possible?
  4. iddqd
    iddqd Minimodder
    6 Feb 2006
    It is, but I'd rather buy a complete setup than part it together. But let's run with that:
    If I do a custom loop, I'd need a small pump, small CPU block and 80mm rad. Definitely need to run this as 1/4" I'm thinking.
  5. radodrill
    radodrill Resident EI
    14 Mar 2006
    I'd say get a DD TDX, Black Ice Micro, and a DDC with Petra's Tech top; I'd recommend using 3/8" tubing instead of the 1/4"
  6. iddqd
    iddqd Minimodder
    6 Feb 2006
    Just fill the loop before installing? I'd like it to be as internal as possible, so resovoir is out of the question huh?
  7. radodrill
    14 Mar 2006
    All depends; some people fill/leak test outside the case. I find it easies to lay out the tubing with the other hardware installed, then have just the pump powered during filling/bleeding.
    Reservoir or T-line will both work; T-lines are more compact though; if you go with a res (maybe the Swiftech Micro Res) either put it somewhere where you can easily access it, or tuck it out of sight and leave enough tubing to pull it out where it's accessible.
  8. samkiller42
    25 Apr 2006
    Swiftech did have a Pump/Res combo, that fits in a single cd drive bay.
    Was easy to fill too.
    Sorry, couldn't say much more.
    Sam
  9. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
  10. radodrill
    14 Mar 2006
    I wouldn't go with the pump/waterblock combo unit; primarily because you're stuck replacing the whole thing if the pump fails.
  11. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Not sure if they're still made but have you looked at the C-Sytems pumps? fairly small cube shape
    RwD
  12. Cyprio
    2 May 2006
    How is that really any different from having to replace a failed pump in a loop. You would still have to drain the whole loop etc etc.
    No?
  13. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Are you using a discreet graphics card? If not then there's plenty of room for everything inside.
    If you are (which is most likely the case) you may have to have the radiator on the outside of the case, are you opposed to do some customising of the case with a dremel?
    You could have a DDC pump where the floppy drive goes (cutting out the bottom of the bay as the pump wont fit otherwise)
    Pics would be a help for fitting everything in.
  14. radodrill
    14 Mar 2006
    The difference is that with the combo unit you'd effectively be replacing both the pump and the waterblock; rather than just the pump.
  15. iddqd
    iddqd Minimodder
    6 Feb 2006
    I have been thinking about the DDC pump. If I do that, I'd do a res in the 3.5" bay (there is 1 open atm), or in the 5.25" bay (and use an external DVD drive). These are the specs:
    2.6 Ghz 533 P4 Northwood
    Shuttle SN41G
    768MB RAM PC3200
    80gb 7200 WD
    BFG 6800 256MB
    I have enough room for the 80mm rad mounted inside, with a shroud + fan on the outside. The proc block will need to have smallish barbs, though; I have about 4 in. clearance in height.
  16. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    You could use right angled barbs on the CPU block thus avoiding clearance issues. For the Res don't use acrylic ones as they tend to crack and leak.
  17. iddqd
    iddqd Minimodder
    6 Feb 2006
    Any good resevoirs I should pay attention to that aren't plexi? Namely 3.5" or 5.25" bay resevoirs?
  18. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    They all seem to be acrylic these days. But I don't trust them.
    What about something like this? Trying to avoid having the DVD drive external but may have to go for something like that. What about a DD fillport res? Or if you get the DDC you could have one of these.
    EDIT: For the CPU block this is low profile so would fit quite easily.
  19. radodrill
    14 Mar 2006
    I personally would steer clear of Koolance products; I'd stick with Swiftech, DangerDen, EK-Waterblocks, D-Tek, Hardware Labs, Thermochill, and LIANG.
  20. iddqd
    iddqd Minimodder
    6 Feb 2006
    HardOCP loves Koolance, so it's worth considering (imo). I REALLY like that bay pump/res, but the whole "don't run me dry" thing worries me a bit.
    I think best case scenario for me is a bay/pump combo and a low profile block like that. $200 for that setup is not bad!
