Modding Planning Your Case Mod
Discussion in 'Article Discussion' started by Guest-16, 23 Mar 2007.
  1. Guest-16
    Guest-16 Guest
  2. Guest-2867
    Guest-2867 Guest
    Excellent guide, I think you covered just about every base, ther's nothing more dissapointing on these forums than when a project log disapears or goes wrong through bad planning
  3. oddball walking
    oddball walking ...!
    21 Sep 2005
    Thank you just what I needed.
  4. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    excellent guide, and helpful.
    I'm using Solidworks to design my own potential mod, but I'm suffering from lack of material information. Being in the US actually does have disadvantages, I can't really use most of the material discussions and information here as it is all european/UK and the shipping costs from there would bust the budget.
    As for the stuff in the catalogs here (mcMaster Carr, for example), I can't afford samples to see what would be best to use.
    I think something that would be very helpful to prospective modders would be a cohesive list of good materials available for given regions (US/UK/EUR)
    Great article!
  5. Guest-23315
    Guest-23315 Guest
    Very nice guide there....
  6. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Us canucks have the same problem. Can't find a 1mmx400x1200mm sheet for the life of me :(
  7. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    hey another great article
    just what i needed to start up my planning agian!
  8. €gr€s
    €gr€s What's a Dremel?
    2 Sep 2006
    very good guide... really..
    but i belong to the group of "improvisators".. i have my ideas and probably whole project in my mind only... and i havent met any big problems yet.. but.. i think you are right, without good planning it is very hard ;)
  9. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I fit into the "bright but lazy"
    Great ideas
    Can be done
    Have the skills
    Have the budget
    BUT... I'll stick to sleeping in the bed :hehe:
  10. LoveJoy
    LoveJoy What's a Dremel?
    22 Apr 2006
    Love it they dont teach that in school eventhough im studying at craft and art school :p
  11. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    Nice guide, gonna use it very soon :p
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    hey, the writing in that article was not half bad! Peter Dickinson, good job on a great article!
    i'll be building a new machine in the summer. it's unlikely to see any major mods but i may have to 'personalise' it a bit....
  13. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    not bad, My whole degree is built around actually metal fabrication and design/theory and engineering. I work in the manufacturing sector during the day and I've had chances to build some pretty sweet things with other peoples money.
    I would like to add that no matter how simple plan on everything taking twice as long as you think it would and costing twice as much as you would think it would.
    I'm a poor college student so my money is thin and now adays I try to keep my cases cheap. Something that is more expensive might not look or be built better, You can do a lot with simple materials and skills depending on how you plan.
    remember that sometimes something may be difficult to make from scratch (lets say a metal sphere) but easy to find from some company who makes that part for a living, or from some premade part (two propane tank ends put together). It can save you time and money in the long run to adapt something that exists then trying to fab a bunch of things from scratch.
    Also as a rule I say don't mod the case you are currently using if your like me, taking your main computer offline is the equivalent of going cold turkey from smoking. It's nice to be able to build a mod hastle free and only swap parts in when you need to size something up.
    oh and finally the bigger the projects the longer it will probably take
    (check out my project log start dates)
    good article planning and fabrication is definately a series of learned skills, you'll find some designs can be made with the bare minimum of planning, and some will need many hours and specific blue prints/cad drawings. I really agree flexibility and creativity will get you really far.
  14. neillyb
    neillyb What's a Dremel?
    7 Jan 2005
    I haven't got a clue
  15. Neji
    Neji Minimodder
    3 Jan 2006
    That's a great guide. In my first mod, I got overambitious and found out I could't do everything I wanted due to lack of.....just about everything. In my current project, I'm following the advice of that guide as much as I can.
  16. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    i think that this is an excellent article/guide, Esspecially where it says
    i spent a while doing concept drawings for my mod '2en' but not much time planning space and costing, and i will do a lot more of both of them for the next mod i attempt. however i have learnt so much from this mod that i doubt i could have planned for the majority of things i have had to overcome any way.
    My mod is in no way shape or form even close to being as good as some of those on this forum, and that frustrates me however my next one will and if not the one after will be. this weekend was the first time i ever worked with resin and had i known how good a product it was a lot of my bondo work would have been replaced (saving me Time, effort and Money) but there was no way for me to know untill i actually got my hands dirty so to say!
    anyway i will be updating my worklog soon be sure to check it out (see sig)
  17. Zut
    Zut What's a Dremel?
    5 Feb 2005
    Excellent article. :D I think I'll be reading this one several times over!
  18. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Thanks for the positive feedback all. :)
    The article is more an overview of common considerations than an exhaustive guide, as everyone has different approaches to planning; I can only speak from my experience and what I've seen around the forums here and on other sites over the last few years, so I may have missed the odd thing. I'm glad some found it useful.
    I'll be covering a few other areas of modding, in a similar fashion, in upcoming articles.;)
    Now get planning (and modding)! :dremel:
Tags: Add Tags
