Modding Plastic Spheres
Discussion in 'Modding' started by Twernmilt, 26 Sep 2003.
  1. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    Ok I have been to hell and back (and yes i've looked at the useful links stickey) and I cannot find a place to buy a few plastic spheres about 10 or more inches in diameter. Can anyone help me out?
  2. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Try lighting supply places, Such as all-phase or others, and find the street light style, the domes on those are spheres, with a hole in one side to fit over the bulb...
  3. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    I thought usplastics had some, I guess I'm wrong, this post has no point really. What are you using them ofr or is it top secret...
  4. RancidFlannel
    RancidFlannel What's a Dremel?
    25 Aug 2003
    security
    i'm not sure about clear, but security stores have dark shaded domes for use in stores, you know, those domes you see overhead? they have some pretty nifty shapes... and if you cant find any, find 2 other dome shaped objects, heat up the acrylic, and cast a sphere yourself, just make sure you have a good heater
  5. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    Try some craft (think of ladies types of craft stores here) stores as well, this time of year with Ch*****as coming up, there are a lot of people who like ot make little diorama type tree ornaments, and put them is side of these clear balls they can hang from their trees, wreaths ect.
  6. Twernmilt
    23 Sep 2003
    I looked there they have some but they stop at like 6" i think wich is far too smal, and i'm making a case some time int he future that is a sphere with water and oil interacting around the outside. It's difficult to explain which is why I didn't try.
  7. OrbDemon
    OrbDemon What's a Dremel?
    6 Jul 2003
    Go to a pet shop and look at the fish tanks. You may find something of use.
  8. pranks7er
    pranks7er mange tout
    25 Dec 2002
  9. Digitalblueshift
    12 Feb 2002
