Playstation 2 > VGA adapter???
Discussion in 'Hardware' started by Carbon, 26 Jul 2004.
  1. Carbon
    Carbon Banned
    8 Jan 2003
    Do these exist? i cba to use the ps2 on my 14inch screen no more so im looking at getting on so i can use my ps2 on my 17inch crt
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Yes they do exist and are available from GAME for around £30 iirc. Only thing is they limit you to 800*640 res.
  3. Carbon
    Carbon Banned
    8 Jan 2003
    what res do they play on a 'normal' tv then?
  4. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
    The PAL tv standard is 720x576, and I think -H- means 640x480 res?, cos 640x800 would give a weird aspect ratio.
  5. Hiren
    15 May 2002
    No it's 800*640 and you get black borders on the screen to make the screen the correct size 720x576 like bmh.01 mentioned.
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    You will actually get a better image using the 14" tv if its a pal-> vga conveter you want. Is there a hdtv output cable for the ps2, if so, that would be better (htdv =RGBHV ;)).
  7. Carbon
    Carbon Banned
    8 Jan 2003
    hdtv = using pc monitor?
  8. Xen0phobiak
    8 Aug 2002
    Basically, was thinking of it for my xbox once, read up on a few ps2 forums.
    is there a ps2 equiv to xbox-scene?
