News PlayStation 4 Firmware 4.50 blamed for Error NW-31297-2 Wi-Fi bug
Discussion in 'Article Discussion' started by Gareth Halfacree, 23 Mar 2017.
  1. Gareth Halfacree
    4 Dec 2007
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    I dropped the awful 2.4ghz only wifi in favour of ethernet as soon as I got mine.
  3. Gareth Halfacree
    4 Dec 2007
    I've just done the same with my Sky Q box, 'cos there's been a known issue for the best part of a year whereby it stops loading thumbnails and pops up network connection errors even though the network is actually working fine and things are downloading exactly as they should.
    Also because the 5GHz support is absolutely broken. Seems that Sky expect you to have 2.4GHz and 5GHz networks sharing the same SSID, so when you scan for a network it only scans the 2.4GHz channels. Connect to one of those, and if there's a 5GHz connection with the same SSID and password it'll connect to that by preference - but there's no other way of doing it. I run 2.4GHz and 5GHz networks on two SSIDs, so I can choose which each of my devices uses, and the Sky box just won't have it: input the 5GHz SSID manually, connection failure; turn the 2.4GHz radio off entirely in the engineer's menu, connection failure and nothing shows up on the scan. So annoying!
    </rant>
  4. lacuna
    lacuna Minimodder
    9 Aug 2004
    I have always had my PS3 and PS4 on ethernet. Problem avoided!
  5. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Yeah, me too. I always opt for a wired connection wherever possible.
  6. Mister_Tad
    27 Dec 2002
    Wow, this is so convoluted and utterly moronic. Surely it took extra dev effort to do this versus, you know, the sane person's way that everyone else uses?
  7. jinq-sea
    15 Oct 2012
    The sky q problem drives me utterly insane. The damned box even turned Wi-Fi on one evening as a result of an update. It brought my whole Unifi universe down. It's mental.
  8. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    I'm guessing it's not an issue for everyone? I upgraded to 4.50 and have to use my PS4 on WiFi for certain things (covered by NDAs) and it was fine. Hopefully it doesn't stop being fine :worried:
  9. Locknload
    Locknload Jolly Good Egg
    28 Jun 2009
    I had this similar issue with dual SSID on my new LG tv. It will not allow me to connect wireless at all now?
