Modding Playstation Controller on PC
Discussion in 'Modding' started by A13n0rma1, 26 Feb 2004.
  1. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Does anybody have a link or guide of their own on how to do this?
    I remember seeing it awhile ago, but I can't find it in my bookmarks nor can I seem to find it on google.
    I also know there's a plethora of converters available online, but I'd prefer something I can build my own and customize it to fit into a case I want to build. :naughty:
  2. cgsimons_2000@yaho
    cgsimons_2000@yaho What's a Dremel?
    12 Jan 2004
    I have seen one, but don`t remember where... sorry
    I just remember they modded it to a usb contact.. :)
    Edit: This didn`t help much, but atleast now you know its out there
  3. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    As far as I know, most PS2 to USB convertors utilise various special components which are difficult to get hold of. Most of the guides available online show you how to wire them up to a spare parallel port, which is just as good and can also support multitaps. I bought a converter - pretty cheap (£5.99) from Play.com and it works ok - u could always get one, gut the plastic housing, and mod the circuit into yr case i suppose.
    PsxPad is the best driver to use btw.
  4. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    That's what I'm lookin for, the parallel port one, as I have a multi-tap [ er, will... ] and the actual controller/memory card thing from my PSX [ I integrated a couple memory cards and converted the controllers to use D-subs just recently. Still modding :dremel: ]
    But anyway, I'll keep googling.
  5. Morphine
    Morphine weeee!
    23 Feb 2002
    use google.com there are about a million guides that ive seen.
  6. savethegaywhales
    savethegaywhales What's a Dremel?
    17 Feb 2004
    If you are looking to buy one, this is what you want.
  7. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    I used this guide here for mine. Works ok, but drivers for it are a bit touchy. I ended up buying one from Play.com as they work a lot more reliably.
  8. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    So far the 3 guides I've seen are all the 5 diode method like that, so out of curiosity what drivers are you using?
    2 sites recommend DirectPad Pro 6, or PSXpad
    Edit:
    The megatap [ 4 controllers on one parallel port ] is here.
    That dude's page also has links to a USB PSX interface guide, but it requires programming an IC.
    Oh, and the NTPad drivers, while elusive, appear to work best on XP machines. All others are usually optomized for Win98.
  9. severedhead
    19 Dec 2002
    I found the NTPad drivers worked the best, closely followed by DirectPad. Others as you say are mainly for 98.
  10. prophecy421
    prophecy421 What's a Dremel?
    30 Jan 2004
    There is a guide online on stepe to make one and it plugs onto your parallel port, but there is a usb version available for pretty low cost. (I paid $9.99 U.S.D. for mine at my local radio shack of all places) I figured this was a tad bit easier and less time consumimg. it works great with the original contoller, dual shock analog controller works great, the vibration also works. it also suppposedly works with the dancemat, fishing rod, and light guns as well.
  11. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Good thing you pointed that out! :D This thing looks ****ing hackable.
    Seeing as how I have most of the stuff for the parallel port one [ and no free USB ports ] I'll try it and see. But thanks for the pointer :thumb:
