Planning Please Delete.
Discussion in 'Modding' started by Foregasm, 13 Apr 2012.
  1. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    Hello Bit Tech Universe!
    The following is the final plan for the Foregasm gaming PC.
    Case: Lian Li PC-7FN
    Processor: Pending (will most likely be an Ivy Bridge i5)
    Mobo: ASUS P8Z77-V LE
    VGA: ASUS ENGTX560 TI DCII TOP
    RAM: G-Skill Sniper 8GB RAM
    CPU Cooler: Cooler Master Hyper 212 EVO
    Boot Drive: OCZ Agility 3 120GB SSD
    Storage: Samsung Spinpoint F3 1TB 7200 RPM HDD
    PSU: OCZ ZT Series 650W
    The color scheme for this build is going to be red and black. The red will be provided by red 3M Di-Noc carbon fiber film, and I'm ordering some of the black carbon fiber film as well. The red will be present on the external drive bay covers, and possibly in a red LED vandal-resistant switch.
    Please leave any more ideas for the build, but I will let you know that I don't intend to cut into the case; it's my first case mod, my first home built computer, and it's a Lian Li case!:D
  2. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Sounds awesome dude, I was looking forward to gold but black and red sounds good too :thumb:
  3. Foregasm
    3 Apr 2012
    I really like carbon fiber, and when I found out it is available in red...I plan to get much more involved in case mods, and black and gold is definitely my next color scheme! And by then, I'll have access to powdercoating, a fabrication shop, and a proper paint booth!
  4. ninjaplease
    11 Jan 2012
    Sounds very promising. Get a couple of decent projects under your belt and you'll be in a position to look for sponsorship ;)
  5. Foregasm
    3 Apr 2012
    When you wish upon a star...:D
  6. Foregasm
    3 Apr 2012
    UPDATE: changed the mobo simply for aesthetics. ASUS Maximus V Gene.
  7. Foregasm
    3 Apr 2012
    as long as we're on the subject of aesthetics, can i get some opinions on using gold to accent the red and black?
  8. Foregasm
    3 Apr 2012
    Gold leaf, brushed gold, machine turned, or gold mirror?
    EDIT: I think i'm going to go with the gold leaf. its the goldest.:D
  9. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Gold leaf sounds intriguing!
  10. ninjaplease
    11 Jan 2012
    Why not spray things like fan grills cold then "carbon fibre" the front so that from certain angles you can see the gold on the inside faces of the holes?
    Also, just so you know, you can edit your previous posts rather than having to make a new post each time. Ofc it's not like it's a problem, just thought I'd let you know incase you didn't already.
  11. Foregasm
    3 Apr 2012
    there really aren't any fan grills. see?
    just a filter
    I was gonna do the front red, and the bay covers gold.
  12. Foregasm
    3 Apr 2012
    I like the idea of spraying the grills, if its possible.:eyebrow:
    here's the basic idea of what i'm going to be doing.
    but i'm ordering new fans, which i'm going to spray gold.
  13. Foregasm
    3 Apr 2012
    thinking about doing the bay covers a matte red or red carbon fiber, and then doing the fans and grills gold. opinions?
