Please Help - Icybox docking station connection
Discussion in 'Tech Support' started by jubei2k1, 31 May 2008.
  1. jubei2k1
    jubei2k1 What's a Dremel?
    9 Mar 2008
    I am having trouble installing new Icybox IB-290 Docking station.
    Have purchased 2.5" WD Scorpio 320gb HD to go with it which I have initialised and formatted.
    HD enclosure that came with docking station connects fine via USB but when connected via docking station which uses a eSATA/SATA interface my system does not detect the drive either when connected prior to switching on or while system running.
    I am using an ASUS P5N32-E SLI Motherboard based system running Vista Home Premium 32 bit.
    I have upgraded to the latest forceware drivers.
    Have I missed something, done something or is the enclosure broken.
    Thanks in advance.
  2. culley
    culley What's a Dremel?
    12 Jul 2006
    Sorry if i misunderstand you, Are you saying that you have connected the HDD to the docking station, and that when its connected via USB it works no problem but when its connected via eSATA it doesn't work?
    If so its probably the eSATA cable that isn't working.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Looking at the connections on the motherboard's rear I/O panel, there's no mention of SATA - never mind eSATA:
    1x PS/2 Keyboard port(purple)
    1x PS/2 Mouse port(green)
    1x Optical + 1 x Coaxial S/PDIF Output
    2x LAN (RJ45) port
    4x USB 2.0/1.1 ports
    1x IEEE1394a port
    And the internal connections include:
    3x USB 2.0 connectors supports additional 6 USB 2.0 ports
    1x Floppy disk drive connector
    1x IDE connector for two devices
    6x SATA connectors
    8x Fan connector: 1 x CPU / 1 x Power Fan / 1 x Chassis / 5 x Optional
    1x Front Panel Audio connector (on SupremeFX audio card)
    1x IEEE1394a connector
    1x S/PDIF output connector
    1x Chassis Intrusion connector
    24-pin ATX Power connector
    8-pin ATX 12V Power connector
    System panel connector
    Again... there's no mention of eSATA.
    So how were you able to connect the enclosure to your PC via eSATA, when the motherboard has no native eSATA ports?
  4. capnPedro
    11 Apr 2007
    You can get SATA to eSATA cables can't you? I thought eSATA only added power and a locking connector. And maybe some shielding or something for longer runs.
  5. Hazardous
    21 Jan 2004
    You can indeed ;) But the OP doesn't mention that's what he/she is using?
  6. jubei2k1
    9 Mar 2008
    Thank you everybody for your replies so far, I will clarify some of the points raised,
    The enclosure has both USB and esata on the rear. I have connected via USB and this is fine and I have not been able to test the esata as pointed out my motherboard does not have this but I will look to get a converter to try and test it on the internal sata ports.
    The enclosure came with a 3.5" bay docking station which connects to the internal SATA ports and is powered by a molex power connecter. It is via this the hard drive is not being detected. At present I am unsure whether the fault is on the enclosures chipset or the docking station connector. I will try to source a converter as mentioned to confirm this.
    Thank you again but I am starting to fear it is broken unless I have missed something.
  7. fathazza
    fathazza Freed on Probation
    20 May 2002
    hi mate,
    just to let you know ive recently bought the same one of those icybox enclosures and docking station combos
    and the sata isnt working for me either, on internal docking station or external through esata.
    it works fine on usb...
    my mobo is an asus P5N-E SLI
    this is the enclousre in question
    http://www.scan.co.uk/Product.aspx?WebProductId=788375
    did you ever sort it jubei?
  8. fathazza
    20 May 2002
    well i got it working on esata buy updating the driver for jmicron the jmicron chipset on my mobo.
    Still no joy with the docking station part :( i think it might be a power problem rather than sata as the power light should come on even if the sata isnt working...
  9. locrieth
    locrieth What's a Dremel?
    2 Apr 2009
    Hey,
    Ive just bought one of these icy box docking stations too and ive got the same problem. Works fine with usb externally, but when plugged in to the docking station the power light comes on but there is no activity on the hdd light on the left hand side. Its not seen in bios either when rebooted with the drive in situ. Did any of you guys find a solution or did you just returned them?
    Cheers.
    p.s. when i was fiddling around with the settings (i.e. whether the power switch was on or off on the back of the enclosure) it did rocognise the drive once, but after a reboot it never saw the drive again, whether the switch was on or off, or if the drive was already in on boot or inserted after.
    :wallbash:
