So i just put a new gtx 560 ti into my computer and everything seemed fine but when i installed the latest version of the nvidia control panel, i clicked on the various menus fine but as soon as i clicked the 3d management settings the thing just crashed... now everytime i go into the nvidia control panel it crashes and i am unable to change any settings.. can anyone help me please!? I have played games ok so i don't think there's anything wrong with the card but im just not sure
Did you do a clean install when you installed the latest drivers? What i do, is when I install the Nvidia drivers, I click on Custom setup, remove Nvidia 3D Vision component (as it's useless to install them, as I don't have Nvidia 3D stuff nor monitor for it), and check the box option to perform a clean install.
Might be worth uninstalling all the nvidia stuff, running driver sweeper and then reinstalling the nvidia stuff as GoodBytes said.
So I uninstalled everything and installed the newest beta drivers and of course it crashed but now it tells me that the error relates to the following files: C:\Users\USER\AppData\Local\Temp\WERD96D.tmp.WERInternalMetadata.xml C:\Users\USER\AppData\Local\Temp\WERF1ED.tmp.appcompat.txt C:\Users\USER\AppData\Local\Temp\WERF400.tmp.mdmp Any idea what this means??
