Electronics please help quickly!! changing 12v to 4.5v
Discussion in 'Modding' started by jmarks1998, 30 Sep 2003.
  1. jmarks1998
    jmarks1998 What's a Dremel?
    30 Sep 2003
    I need to know what resistors I will need to step 12 volts down to 4.5 volts or how to calculate it. Please help. Please!!
  2. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Yur safer using a regulator, a 5v 7805 should be near enough. :)
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Plus a 1N4001 diode or similar on the output, and you'll get around 4.5V.
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    what are you using it for?
    if the current is varying you have to use regulators, but if it's leds or something a resistor should be fine... still need to know current though...
