Cases Please recommend me sub £150 case
Discussion in 'Hardware' started by Synay, 13 Apr 2010.
  1. Synay
    Synay What's a Dremel?
    25 Oct 2009
    I'm struggling to choose a good case for my build. It needs to house 4HDDs, 2x GTS 250, full ATX board with an audio card in between GPU's and The Corsair H50. I need on 120mm on the back, some fans at the freont and prefferably at the top as well. Best if aluminium, but as silent as possible. I also need at least 3 x 5.25" at the front. Could someone point me to some good e-tailer? I'm seriously stuck and I need to buy one this Friday.
    Thanks.
  2. Stewb
    Stewb What's a Dremel?
    16 Dec 2009
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
  4. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    Antec P183?
    I've got the predecessor, the 182. Only complaint is space for full-length graphics cards (like my GTX 260) depending on where the power sockets are, but good sound insulation, decent heat dispersal & solid.
  5. Synay
    25 Oct 2009
    Thanks, but I need something bigger. Had the mini version of this series, good, but I want better cooling and space.
    As for the Cosmos. Ph4ZeD, I am thinking about that too. I see you have one, could you advise me on it's day to day noise levels. I presume inside is very spacious as it's a full tower case.
  6. Ph4ZeD
    22 Jul 2009
    The inside is indeed extremely spacious, I could never go back to the smaller cases. Even with full length cards such as a 9800 GX2 which I had in there, there was plenty of room against the end of the card and the hard drive area. I wouldn't say the case is especially quiet or noisy, depending on the fan setup. It doesn't have the extensive vibration dampening of cases such as the Fractal but I don't find it noisy compared to other cases. The nosiest component in my case is my Fenrir, my 260 GTX is virtually unhearable. You have a H50 cooler so that should be quieter.
  7. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Coolermaster Stacker 832 or a Coolermaster Cosmos S
  8. Synay
    25 Oct 2009
    What do you think about this?
  9. Teelzebub
    27 Nov 2009
    The coolermaster cosmos is huge you could live in that, I've got a coolermaster stacker not as big but has 7 120 fans and houses my SLI system with loads of space left.
  10. bagman
    bagman Minimodder
    18 Apr 2009
  11. shah
    shah Minimodder
    29 Jan 2010
    Lian li b25f is a very good case and build quality is stunning but i found it noisy.
    I have a fractal R2 and it is very quiet. Not very spacious tho but it can hold 8hdd and handle any graphics card. i also have a Corsair H50. i have some pics of the build in my profile.
