A/V please recommend...
Discussion in 'Hardware' started by Rowland, 20 Sep 2010.
  1. Rowland
    Rowland PC Gamer
    6 Sep 2010
    can anyone recommend a great 5.1 sound system for gaming purposes ?
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i am currently using logitech x-530 speakers, and get complaints from the lads i game with as they set off the mic on ts, at relatively low volumes, bass is the biggest problem, as even though the sub is turned down, bass response is good
  3. Gareth24
    Gareth24 Folding = vdubs
    16 Jun 2009
    +1 for the x-530's great set of speakers and you can pick them up quite cheap second hand (I got mine for £20 off here.)
  4. Rowland
    Rowland PC Gamer
    6 Sep 2010
    thanks fellas !
  5. sp4nky
    sp4nky BF3: Aardfrith WoT: McGubbins
    15 Jul 2009
    I'd go with the Logitech Z5500 myself.
  6. Parge
    16 Jul 2010
    The Logitech Z-5500s are absolutely amazing.
  7. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    Totally depends on your budget, and how fussy you are about sound
    For cheap(ish), the Logitech X-530 or X-540 sets are both decent for the money. (if you can get them for £20 its a steal)
    Next (big) step up are the Logitech Z-5500 at around £250. These are generally agreed to be the king of 5.1 computer speakers, and assuming you're not used to HiFi sound, will sound very good. I wouldn't call them absolutely amazing... but then it all depends on what your comparing them too.
    If your fussy about sound, 5.1 might not be the way to go, but for gaming it is good :)
  8. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    +1 for the Z-5500's
    you may like to check the For Sales section as soneone is selling a set for £150. Here.
  9. Jipa
    5 Feb 2004
    Also remember that either you place the speakers properly around the room or you're just wasting your money on the center + rear speakers. It makes me sad to see people shell out money on Z-5500 and then be too shy to put the rear speakers where they belong.
  10. RichCreedy
    24 Apr 2009
    that reminds me, i must set my speakers up properly, when i have time, lol, rear speakers are currently just laying on floor
