News Plenty of Nehalem boards on show
Discussion in 'Article Discussion' started by Da Dego, 6 Jun 2008.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. wyx087
    15 Aug 2007
    interesting core orientation on the Intel board.
    hope we'll still have as much freedom in heatsink mounting direction as the current square ones.
  3. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    where's the DFI ones??????
  4. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    I wish more boards were like the intel board. It goes with airflow very well.
  5. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    What's the point in new motherboards if they aren't pretty? More copper!
    Uh, otherwise the heatsink mount holes look to be square... good, any orientation.
  6. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    Do the Dual Processor Nehalem boards use FB-DIMMS?
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    i think it is time for pci to die....
  8. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    DFI has always been slow to the new chipset party. Expect them to be fashionably late, to the point of X68 being on the verge of release :p
  9. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    perhaps you should tell the expansion card manufacturers that :p
  10. Goty
    Goty Minimodder
    13 Dec 2005
    It's nice to see some high-end Intel chipsets that don't require massive northbridge heatsinks and a ton of heatpipes to cool it, again.
  11. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    is it just me or are the heatsink mounting holes excessively far away from the socket wall? ... and PCI still isn't used to its fullest bandwidth. I agree with you Goty, nice to see it aswell, silence and functionality are key. Am curious to hear the full detailed specs of X58 and its partnering components.
  12. Guest-16
    Guest-16 Guest
    Don't be too sure - these are very very early boards.
    RE: FB-DIMMs, you know, I completely forgot to ask but I would say no - they are simply Registered ECC DDR3 because they've no need to be fully buffered anymore as there's no central MCH and no need to reduce the trace count.
  13. Djayness
    Djayness phwupupupup
    7 May 2008
    Has asus ever made a board, more bland, more ugly than that....looks like someone chose a terrible pcb colour.
  14. Guest-16
    Guest-16 Guest
    Think about it this way - if Intel asks your for support, you will want to be there. However, by being there all the competition knows what you are doing, so this is the only way Asus gets to win at both keeping its cards close to its chest and providing support.
  15. naokaji
    naokaji whatever
    8 Dec 2006
    I'm not sure just how many heatpipes and how many tons of copper color painted aluminum they will slap on those boards, afterall x58 should use far less power due to Nehalem having IMC.
    That they neither deny nor confirm that x58 will be called x58 is rather stupid though, especially considering they have boards with x58 in the name at their own stand.
  16. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Very odd Intel board... everything is the wrong way round and the memory slots have three of one colour and one of a different colour. Is this catering for some processors have 3 channel memory (the 3 blue slots) and some having 2 (some other combination)?
    And I suppose x58 will be cooler running now it doesn't have to do memory controlling.
    edit: the post doesn't seem to link here, though I may be being stupid.
  17. Goty
    Goty Minimodder
    13 Dec 2005
    That was my line of thought, too. If Intel still can't get the power consumption of their chipsets down after removing the vast majority of the logic from their northbridge, that's pretty sad.
  18. ssj12
    ssj12 Minimodder
    12 Sep 2007
    nVidia needs to definitely license intel SLi tech so they can get SLi into these boards
  19. Icy EyeG
    23 Jul 2007
    Cool! :) As they wasted a lot of energy IMAO...
  20. Guest-16
    Guest-16 Guest
    That's not true - X58 uses MORE power because of the super fast high frequency QPI links. At least, in its current revision it does - this could change.
    ssj12 - it's not about Intel Licensing SLI, it's about Nvidia letting Intel license it.
Tags: Add Tags
