Modding Plexi Glas?
Discussion in 'Modding' started by kastman, 4 Dec 2002.
  1. kastman
    kastman What's a Dremel?
    31 Jan 2002
    Hello all you computer modding fanatics out there :p now it is time for me to make my second case in plexi glas. But i dont know how i can bend 5mm plexi in a safe way i know it involves heat... sooo anyone got any idees?.. My current case is in plexi glas but i have not bent anything on it..
    Regards
    // Kastman
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  3. Transic
    Transic What's a Dremel?
    4 Dec 2002
    That really is huge, id try to find something a little smaller. Eddie_dane is likely correct in saying that .25" is about the max for the current DIY heat gun bending...I guess if you had some specialized bending apparatus...
    Transic
  4. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    It would depend on the sharpness of the bends. If the corner had a large radius the thickness wouldn't be as much of a problem.
  5. Transic
    4 Dec 2002
    I hate to disagree, but i think that because of the time it would take to heat the plexi into its semi-liquid state, you would get defects in the plexi..
    Transic
  6. Blackness
    Blackness What's a Dremel?
    4 Dec 2002
    What you need is a thing called a strip heater. My school has one.
  7. linear
    linear Minimodder
    5 Oct 2001
  8. Transic
    4 Dec 2002
  9. linear
    linear Minimodder
    5 Oct 2001
    Yeah, check out the price he's got on those Foredoms. Click the specails link off his front page. :naughty:
    Edit: and welcome to the boards, blackness.
  10. Transic
    4 Dec 2002
    Have you bought anything from him? If so what was your experience? (namely looking at the acrylic)
  11. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    What about using a metal pipe, pumping the heatgun's air into, and using that as a heat strip?
    As long as you don't let it get hot enough to melt the plastic to the metal.
    Hmm, new case Idea!
    Build a metal frame and bend all the plexi over it.
    Leaving a metal/plexi combo case, but with curves.
  12. linear
    linear Minimodder
    5 Oct 2001
    No. Sorry. I think nesbit has.
    Check out the last design rendering on this page.
