Modding Plexi glass tubes
Discussion in 'Modding' started by olle, 30 May 2012.
  1. olle
    olle What's a Dremel?
    26 Nov 2005
    Hi everyone!
    A friend of mine just gave me some plexiglass tubes 13mm OD and 10mm ID.
    Now I´m wondering if it exists any fittings for that size?!
    Anyone....?
    /Olle
  2. Unicorn
    25 Jul 2006
    3mm Plexi will have to have some pretty fine threads cut in it, but that'll work, yes. You can cut a 10mm thread on the inner diameter and screw a 10mm threaded fitting into it.
  3. Cheapskate
    13 May 2007
    I think he means SLI fittings, but to my knowledge they are only 12mm OD.
  4. olle
    26 Nov 2005
    Cheapskate is right, the material in the tubes are 1,5mm thick. I dont think I can cut threads in that...
