Modding plexi question.
Discussion in 'Modding' started by kastman, 3 Jun 2002.
  1. kastman
    kastman What's a Dremel?
    31 Jan 2002
    A little question about plexi. What can i use to smoothen the edges/corners so they become round and they still got the plexiglas finish. It is kind of ugly with the sharp corners i like them smooth. i will get pictures upp to show what i mean.
  2. mr. phantastik
    mr. phantastik What's a Dremel?
    7 Apr 2002
    I would imagine using a medium sand paper to do the rough shape, then a file to smooth things, then moving up in grits to a final rubbing compound like novus.
  3. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    if you get a torch and hold it a good 6-8 inches, you can melt the edges smmoth again. Very cool technique IMO
  4. MadGamer
    MadGamer What's a Dremel?
    18 Feb 2002
    yeah the torch trick is the best imo
    just be careful not to burn urself :D
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    i used a dremel to round the corners on my plexi. I used one of the sanding belt attahments.
  6. Morphine
    Morphine weeee!
    23 Feb 2002
    get a router attachment for a dremel and get a router bit to make corners round. then file/sand. then apply novus. or use lighter trick
  7. LaPPe
    LaPPe What's a Dremel?
    3 Nov 2001
    Whats a router?
    pic please... :)
  8. Lazy
    Lazy Meow?
    13 Nov 2001
    the dry wall cutting kit for the dremel also cuts plastic according to the packaging but i found it after i had cut 2 80mm blowholes in a piece of plexi to make a card cooler.
    It is only £10 as well.
  9. Morphine
    Morphine weeee!
    23 Feb 2002
    router, router,..... ummm it holds the dremel perpendicular to the material being cut. go to you local hardware and mention router bits and ask to see em. ill get a pic up if i can
  10. jennyfur
    jennyfur What's a Dremel?
    2 Dec 2001
    how convenient, I was actually about to ask the same thing. there's no way I could get ahold of (or have the guts to use) a blowtorch so I'm gonna go with different grades of sandpaper... but this novus stuff you guys keep mentioning, what is that? A polish or something?
    also, there are some very fine scraches/gashes in the area surrounding one of the holes in my window (and I mean really tiny... you can't even see them unless you look really hard). Is there anything that I can use to fill or buff them out a bit?
    Thanks.
  11. Geek
    Geek What's a Dremel?
    21 Nov 2001
    You could use one of the little propane pen guys. Those are much less scary than full-on blowtorches.
    Gordon
  12. Lazy
    Lazy Meow?
    13 Nov 2001
