Modding plexiglass cutting blades
Discussion in 'Modding' started by THEkorean, 17 Jun 2007.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    i need to know how many teeth per inch (blade) and at what speed (high, med, low?) should i cut relatively thin plexiglass with (about 1/16" thick plexi).
  2. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
  3. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    so in other words about 10 tpi (metal blades are fine)
    you might also be able to get away with using a box cutter
  4. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Best bet is to buy a plexiglass cutting blade. I have a 10" blade for my table saw and has 80 teeth per inch. I use it to cut 1/4in stock. and it leave a very clean edge.
  5. Cheapskate
    13 May 2007
    Ouch! you can buy an entire saw for the cost of that blade!
  6. THEkorean
    THEkorean 42
    10 Jun 2005
    thanks for the replies guys, i did some experimenting on my own and found out that blades with a large number of teeth at med - high speeds cuts thin plexi really well, as the glass gets thicker, i use blades with less tpi at lower speeds
  7. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
