Modding plexigless Question
Discussion in 'Modding' started by Zion, 28 Jun 2004.
  1. Zion
    Zion What's a Dremel?
    11 Apr 2004
    where can I get some plexigless. All I can find is some thin cheep crap. Can anyone help me :D
  2. mrplow
    mrplow obey the fist!!
    5 Sep 2001
  3. Zion
    11 Apr 2004
    GOOD LORD, thanks man you rook :rock::rock::rock: i needed that.
  4. coil
    coil What's a Dremel?
    25 May 2004
    Teach a man to fish... (;
  5. Zion
    11 Apr 2004
    and you'll feed him for a life time of modding :D
  6. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    It's not on that list but I highly recommend delviesplastics.com. I have used them for materials for all my acrylic so far and they are priced very well. They only sell cell-cast acrylic as well
  7. [KT] Mike
    [KT] Mike What's a Dremel?
    5 Oct 2003
    I understand the differece between cast plastics and extruded sheets, but often the difference isnt that noticeable, not for our needs anyway, so why do people pay extra (when extruded sheets can often be quite expensive already) for cast sheets??
  8. MrSaLTy
    MrSaLTy What's a Dremel?
    13 May 2002
    Extruded acrylic is way crappier to work with. Cell cast acrylic will not melt when cutting on a table or band saw or while gang cutting. Its also more resistant to chipping and cracking. It also polishes better then extruded.
