News Plextor announces M6e gaming SSD
Discussion in 'Article Discussion' started by Gareth Halfacree, 9 Jan 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Guest-16
    Guest-16 Guest
    That's a massive, massive PCB for such a tiny card. Plextor need some industrial designers on that.
  3. Deders
    Deders Modder
    14 Nov 2010
    Will it really make a difference over Sata when actually gaming? I doubt it.
  4. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    Should have made it to half height card specs and ship it with both brackets so they could sell it to SFF system users too...
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    With SATA Express on the horizon i cant see add-in cards such as this having much market appeal.
  6. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    They should have build it like an 'up gradable' Lego block, so you can add storage modules to it.
  7. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Looks like a decent card, however, pricing is really what matters. If this is much more than a standard S-ATA SSD then the small "real world use" hardly makes it worth it. If it's priced competitively then it's a decent bit of kit.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Have they not seen the daughter board supplied with Asus' Maximus VI series?
  9. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Surely at that potential size (as in remove the unnecessary excess green!) it doesn't even need a back-panel bracket and could just slot straight into the PCI-E 1x slot?
  10. Shirty
    18 Apr 1982
    Are mPCIe SSDs a thing, or will they ever be?
  11. phuzz
    phuzz This is a title
    28 May 2004
    Yes, sort of, go google mSATA for more information. Most netbooks use them.
  12. Shirty
    18 Apr 1982
    Ah no, not MSATA, specifically mPCIe (same socket, different pinout). PCIe x 1 theoretically has a higher transfer rate than SATA from version 3 onward.
