Hardware Plextor M6V Review (256GB)
Discussion in 'Article Discussion' started by Combatus, 17 Feb 2016.
  1. Combatus
    16 Feb 2009
  2. David
    7 Apr 2009
    Never thought I'd be requesting an SSD review but, is there any chance of bit-tech including the Sandisk Ultra II drives in the future?
    These are frequently subject to Amazon and Ebuyer specials, so a look at their relative performance might be worthwhile. However, as you rightly point out in the review, it's usually a case of buying the biggest you can for the least money.
  3. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I'll see if I can source a sample, but as you said I doubt it'll be a game changer!
  4. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Any chance the chart entries could indicate the connection method for the SSDs? i.e. M.2, SATAIII, PCI-E, etc.
  5. Farsan
    Farsan What's a Dremel?
    1 May 2014
    That could be great!
  6. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Is it unethical to buy one from Amazon, test it and return it? Seems reasonably reasonable.
  7. Harlequin
    Harlequin Modder
    4 Jun 2004
    would love to see where my old M4 comes in amoungst the new stuff
  8. Dogbert666
    17 Jan 2010
    Quick update on this - we simply have far too much going on to look back at older drives. Sorry!
  9. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    TBF this is a good point, SANDISK are frequently the best priced drives - on offer that is
    I have had a few and never had any issues and always been impressed...
    They have a lot of models though - why not contact them and do a SANDISK roundup?!
  10. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    I recently saw an announcement for water cooling for an intel SSD, and the poster mentioned it was odd since they do not need cooling according to the manufacturer.
    Then later I read a technical pdf about increasing lifetime and number of cycles on TLC NAND and the design relies amongst others on a few temperature sensors on the SSD PCB because the NAND is seemingly very sensitive to temperature in respects to its lifetime.
    In other words: If you use the modern low price SSD's (TLC chips), then it seems best to keep them cool.
    Install them in a place away from heat I would say, better to be safe than sorry.
Tags: Add Tags
