Modding plexy,acrillick,lexan
Discussion in 'Modding' started by kobaj, 11 Oct 2004.
  1. kobaj
    kobaj Banned
    4 Jul 2004
    1.Is there a difference between the three,If so what.
    2.I think I will yous acrillick (price) for a complete case,Is it strong enough.
    3.How thick should it be.
  2. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Hate to be a spelling nazi, but its spelled "acrylic" not acrillick.
    Acrylic is generally, a type of plastic. Lexan and Plexiglass are two types of acrylic. Plexiglass is usually thin, inexpensive, easily scratched/cracked, and will melt when cut with a rotary tool. Lexan is the better of the two, as it is stronger, generally thicker, a little more expensive, not as easily scratched, and wont melt as fast under a cutting wheel.
    So there you have it. Plexi may be sexy, but lexan will get you laid.
