Build Advice Pls Critque this build
Discussion in 'Hardware' started by blacksta, 23 Jul 2012.
  1. blacksta
    blacksta What's a Dremel?
    1 Nov 2011
    Cpu: Intel I5 3570K
    MB: Gigbyte GA-Z68AP-D3 Intel z68 socket 1155
    RAM: Corsair Memory Venegance Blue 8gb ddr3 1866
    HD: seagate ST31000524S 1TB
    SSD: 120gb kingstom hyperx 3k series SSD SATA3
    Tower: Coolmaster elite 430 black mid tower
    PSU: 650 ezcool silient ps-05
    Cooling: Artic Cooling Freezer 13 cpu cooler
    The system would be used for surfing, streaming , music, word processing and depending on the build might be used for gaming in future
    total Price £ 520
  2. Parge
    16 Jul 2010
    All good apart from the PSU, which is terrible and needs to be swapped for one made by Corsair, OCZ, Enermax, BeQuiet or another reliable manufacturer.
    Also, you haven't got a graphics card, so while it'll be fine for word processing etc, you won't be able to do any gaming.
  3. blacksta
    1 Nov 2011
    Thanks for the quick response , can you recommed a suitable psu and i was going to replace the Motherboard to a ivbridge asus p8z77-v lx - what do you think? .
    In relation to a graphic card i was planning on getting one later or if you recommend a suitable one , might consider.
  4. Parge
    16 Jul 2010
    Sure
    This Coolermaster 500W
    or
    This BeQuiet 530w unit.
    The coolermaster is slightly less powerful (but still fine for your needs) but is modular, which means you only need to connect the cables you need, helping you create a tidier build.
    I'd say changing the motherboar to a Z77 model would be a good idea, and the one you have chosen looks fine.
  5. blacksta
    1 Nov 2011
    thanks Again - what about a graphic card
    If i add a graphic card will that PSU be sufficient
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Would opt for a little more than 500w if there is a dedicated GPU going to be installed in the near future..That said my corsair 520w has been sufficient and lasted me a while, even on my current 2500k/gtx 570.
  7. Parge
    16 Jul 2010
    Yeah, Bit Techs full system power draw with a GTX 670 was only 373W. The days of having to have 600W+ PSUs for single card setups are over.
    That said, you could opt for this 600W Corsair for slightly more cash.
    What would be your budget for a GPU?
    Aria have an open box 1GB 460 GTX for £83.99
  8. blacksta
    1 Nov 2011
    Is it possible to live without a graphic card or is a card solely dedicated to game playing?
  9. Parge
    16 Jul 2010
    Yes, you can use the graphics card built into the CPU which will be fine for everything except gaming. For that you'll need a separate GPU.
  10. glendronach
    glendronach What's a Dremel?
    1 May 2009
    There's more than an outside chance that the GA-Z68AP-D3 mobo will need a BIOS flash to support the Ivy Bridge 3570K. Gigabyte say that BIOS F8 with version 1.0 of the board is ok but it is not always the case that mobos in suppliers' stock are up to date. The revision 2.0 of the board also may need a BIOS flash to BIOS FD.
    The Asus P8Z77-V LX is a reasonably priced alternative.
    The Radeon HD7770 graphics card is, imho, a better option than the NVidia 460GTX.
  11. blacksta
    1 Nov 2011
    Thanks for the advice
  12. blacksta
    1 Nov 2011
    I will go for the 600w crossair - Thanks again
  13. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    ever take a look at an amd A8 or A10 based build?? those have more than enough power for surfing and all and the extra graphics horse power would help with the games in the future!
