Windows Plug-in for Firefox 2.0
Discussion in 'Software' started by Callum, 8 Dec 2006.
  1. Callum
    Callum What's a Dremel?
    4 Apr 2006
    I seem to be missing a video plug in for firefox, as whenever I go to pages such as this, I get a message saying that additional plug-ins are required to view all the media on this page. So I "click here to install the plug-in" and it says that no suitable plug-ins were found, and the following information:"Unknown Plugin (application/x-mplayer2)" and a button for a manual install, which takes me to the Windows Media Player downlaod page. I have reinstalled Windows Media Player, but it doesn't help.
    Is it because I upgraded to WMP11? And should I just go back to WMP10?
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    You can't play WMP files in Firefox. I think it's something to do with the licensing in WMP. View it in IE.
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Runs fine in Firefox 2 over here.
  4. Callum
    4 Apr 2006
    It didn't work when I reverted either. How did you do it then r4tch3t? :p
  5. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    nothing, I must already have the plugin..??
  6. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I've had this problems loads of times. What tends to work is to completly uninstall firefox (100% remove), then install Firefox 1. THEN update it.
    It has worked for me before. You can view Windows Media in Firefox, it's just its very problematic for some reason.
    EDIT: http://forums.mozillazine.org/viewtopic.php?t=206213
  7. Arthur2Sheds
    19 May 2003
    I stand corrected. Thank you.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Works just fine for me and I did a clean install of FF2. Check about: plugins to see if WMP is listed.
    See http://forums.mozillazine.org/viewtopic.php?t=206213
  9. Callum
    4 Apr 2006
    Thanks for the link MrWillyWonka. Those steps worked. Turns out I didn't have the plugin files in the firefox directory, OR my windows media player directory, so I had to copy them from my laptop. All works fine now though.
  10. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Works fine in FF2 and WMP10 here..
