Modding PLZ post your red UV theme pic here; problem with ATX connector too
Discussion in 'Modding' started by psYCHopath, 4 Jul 2005.
  1. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    Hi,
    I'm going to mod my Gateway 2000 ATX tower.
    I have bought
    [x1] UV RED rounded ide cable
    [x1] UV BLUE rounded ide cable
    Cahnged all the molex connectors to easy grip RED UV
    but at the same time i have the 20pin ATX and 4 pin UV Red connector, I dont have the atx removal tool, Is there a guide for it? without using the "special" tool.
    I hanvet mod the side panel...just need some design to begin with.....any site that shows the side panel design sample.... :dremel: plan to etch on the arylic too.
    :cooldude:
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    :search: :search: :search:
    With that said, if you unfold a staple or get a really really tiny jeweler's screw driver you can use those to removed the pins. I would do the pins one at a time so you dont have 2 wires off the ATX connector and are like *Crap where do they all go*. If you move them one at a time, you should be fine. And those atx tools dont work at all, at least mine didnt
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    using the tool, push it in all the way, then yank the wire out the back. be careful not to jerk it, or you may break the tool.
  4. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Yeah man those ATX tools suck, I posted in my project log about that my one broke, one of the prongs snapped off which sucks!
  5. Tulatin
    16 Oct 2003
    especially when they're $35. But i think AC Ryan gives you the molex/floppy/aux/atx removers with their plug replacement kits now. The only problem is that it is IMPOSSIBLE to get those god damn AC Ryan plugs off.
  6. psYCHopath
    25 Dec 2001
  7. tm36usa
    21 Jan 2004
    Yeah, i bought the $30 PSU modding kit and the damn atx removed doesnt even fit in the connector to release the pins. I've tried it on Antec, Tt, Raidmax, InWin and Cooler Master PSUs and it doesnt work on any of them.
  8. psYCHopath
    25 Dec 2001
    hmmm lucky i didnt buy it. it was sold about RM45/ USD 11.80
    so does anyone has UV Red theme on their pc? :rock:
  9. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Some people have had success with the plastic ink tube from a ballpoint pen. I tried it and it didn't work, but perhaps the pen I used was just c**p.
  10. psYCHopath
    25 Dec 2001
    c**p?
    btw i have successfully manage to learn the technique to put out the cable.
    you need to get the bigger size one 24/6 as in the pcmoddingmy guide...
    and
    use the hammer to hammer the "poking" end...so its easier to be put into the side. :dremel:
    BTW does anyone has sample of RED UV rig?
  11. Arkuden
    Arkuden mow?
    9 Jul 2004
    worked perfectly for me and i didnt bother to see if i was posted yet or not but i took an audio jack from raidoshak and cut off the very tip of it. Size is perfect to squeez the pin enough for it to come out with out a hitch. At least thats how i sleeved my machine. Although the sleeving was crappy as hell and it became all frayed.
  12. psYCHopath
    25 Dec 2001
    audio jack?
    Arkuden can you please post a picture of the audio jack
  13. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    They're referring to molex connector removal devices. As for the ATX and 12v plugs, staples work best unless you want to break down and buy the tool
  14. psYCHopath
    25 Dec 2001
    the tool is useless as commented by others :S
  15. Tulatin
    16 Oct 2003
    they're useless not the tool. I've done over 10 PSUs with one of those little ADP tools. Never an issue.
