Development PNGs with odd transparency
Discussion in 'Software' started by jezmck, 4 Feb 2004.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi all,
    First off, I understand how PNGs have an alpha channel and all that, and I know that no browser seems to properly support PNGs.
    If I have a PNG (with transparency) on a HTML page, the wrong colour 'shows through'. Is this an IE issue? Any ideas?
    Sample here. For me, the page BG is white, but the image background is grey. Do you get the same?
  2. 486hawk
    486hawk What's a Dremel?
    18 Jul 2003
  3. The Savior
    The Savior What's a Dremel?
    28 Sep 2002
    PNG compatibility is a known problem for IE. I know that Opera displays them correctly, but I'm not sure about other browsers.
  4. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    yep, ie cant display transparency in png's, everything else can tho :D
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    well looking at the screen shot provided by 486hawk netscape isn't displaying it properly either - it's blending the transparency with black instead of white.
    guess i'll have to not bother with PNGs for a few years...
  6. Hamish
    25 Nov 2002
    this is what it looks like in firebird
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    thanks Hamish - that's how it should look. but given that 80.5% of the visitors to my site use MSIE6, looks like i really will have to wait for proper support. :(
  8. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Hahaha, good luck! Actually, you can get PNG transparency working in IE... do a search on MSDN for filter:progid:DXImageTransform.Microsoft.AlphaImageLoader
    Watch out though, I tried doing that with rollover buttons and it would occationally crash IE, but it's fine for static images.
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    Thanks JazzXP - will have a look at that. :)
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Can't you just use GIF format or is there a reason for you wanting PNG?
  11. jezmck
    jezmck Minimodder
    25 Sep 2003
    I have got the AlphaImageLoader technique working (a little help from howtocreate).
    Ouija: I wanted a particular look only achievable with alpha transparency, but will probably stick to GIFs for now.
    (see here for a demo (IE4+ only sorry), the difference is only slight - the shadow fades to fully transparent in the top image (a PNG) whereas it fades to white, then cuts to transparent in the second)
    PS the background is a white GIF with transparent dots so I can choose the colour of the lines by setting the bgcolor...
  12. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Ah, you can always rely on good 'ol Firebird :hip:. None of that screwed up "coding" (or so Microsoft calls it...IMO its crap :D)
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    yeah, but i can't rely on all my guests using firebird...
    could you guys do my a favour a take a screenshots of how this looks in different browsers? would really appreciate it. :thumb:
