Hardware PNY GeForce GTX 780 XLR8 OC Review
Discussion in 'Article Discussion' started by Meanmotion, 15 Nov 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Shirty
    18 Apr 1982
    Those overclocked results do not disappoint.
  3. David
    7 Apr 2009
    Indeed. They are bloody impressive. Cool running card too.
  4. heir flick
    heir flick Minimodder
    2 Feb 2007
    ive seen these for sale for £370, not bad at all
  5. Shirty
    18 Apr 1982
    If I can pick one of these up for a worthwhile discount in the January sales (preferably £350), my next GPU might just be Nvidia after all. Just need to see what the AMD partners can come up with for keeping the R290 cooler.
  6. jimbok11
    jimbok11 What's a Dremel?
    11 Oct 2010
    Would be good if someone could confirm the power circuitry 'niggle'...still a massively impressive card, but would be good to see if it's an issue across all (or at least most) of these cards.
  7. Gradius
    Gradius IT Consultant
    3 Feb 2009
    I still found the TV output quality (even as HDMI) better on AMD than on Nvidia.
  8. Panos
    Panos Minimodder
    18 Oct 2006
    Where you saw them £370? Because cheapest price is £395 pre-order
  9. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I can only assume that they meant that they had seen a GTX780 for £370 (£377.74 on pre order @ SCAN) and not this particular card, otherwise I think someone was telling fibs... ;)
  10. heir flick
    2 Feb 2007
  11. Panos
    Panos Minimodder
    18 Oct 2006
    Wow cheers mate :D
    Now thats a good price.
  12. heir flick
    2 Feb 2007
    yep not bad but if your thinking about it better hurry up because they had 6 the other day and now down to the last one
  13. Panos
    Panos Minimodder
    18 Oct 2006
    Got one :D
    Lets see how it performs on Saturday.
  14. Panos
    Panos Minimodder
    18 Oct 2006
    Seems bit tech were very conservative to their OC. With same OC settings hit 1201 core with 1293 boost on the first go. And betting bit fiddling going to pass the 1300 barrier.
    FYI the one I got has Hynix VRAM not Samsung.
  15. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Awesome to hear that! Certainly seems like PNY is binning the chips for these cards to a very high level.
    Have you experienced any noise coming from the power circuitry?
  16. Panos
    Panos Minimodder
    18 Oct 2006
    Not at all. Had no coil whine, which was bit prominent to my 7950
    (until let the 7950 run 4 hours valley straight, which disappeared afterwards)
    This card is pretty quiet also. Up to 65% fan speed cannot be heard over 4 Enermax Magma fans that are on the H100 radiator. And these are 18db fans working at full speed.
    Above 65% fan you can hear the card over the Magma fans, but is more quiet than the 7950 PCS+ and nothing to bother you about, if you wear headphones. Have it with fan profile working at 80% at 60C and holding there while overclocked.
    Btw the ASIC is 78.7%.
Tags: Add Tags
