Modding pocket pc mod
Discussion in 'Modding' started by Hellboy787, 3 Jan 2006.
  1. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    i have a old HP Jordana Pocket PC 520 I would like to know if I some could help me to mod the LSD touch screen so that i could use it as on my PC to show me temps of my cpu etc etc
    Does anybody have any idea how to do this....I don't have a clue about those kind of electronics....but not scared to learn....if that helps
    any thing would be a great help...
  2. mattthegamer463
    26 Nov 2004
    ok, completely wrong section. this should be in modding.
    to clarify, this section is for mod guides ONLY, so if you did a pocket pc mod you could make a post in here telling people how to do it as well, but not asking for help on how to do it.
  3. s29feb
    s29feb What's a Dremel?
    29 Oct 2005
    Use Innobec side window and then Konfabulator easy peasy lemon squeezy ;)
  4. ajack
    ajack rox
    17 Apr 2003
    This doesn't necessarily need to be modded - as s29feb pointed out, you can easily do it like that. If you want to strip the LCD and maybe mount it in your case or something, that's going to require a fairly great amount of work (read: laptop screen)
  5. ken0009
    ken0009 What's a Dremel?
    2 Feb 2005
    Concerning Innobec and Konfabulator, you could find helpful informations here
  6. Ryszvaldo
    Ryszvaldo Banned
    3 Jan 2005
    Ken0009 - Fantastic, been after something for this for ages! much easier than a PSone screen mod on my cassiopeia! Yay!
  7. ken0009
    2 Feb 2005
    Great !
    That works nicely but I think that it's not as fast as it could be with a modded PSOne LCD.
    Refresh is quite laggy (tested with x50v in 300x400 pixels). This means : if you plan viewing movies or animations, that won't do the trick.
    In the other hand, simply displaying things like widgets will be ok as they usually don't need 25fps refresh.
    Have fun !
  8. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    another idea could be to use samurize.
    If you pda has a wireless connection or wired for that matter, you can run a Samurize Server on the PC, and then the Samurize Client on the PDA and have wireless stats!
  9. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    Does this only work with Pocket PC's or is there an alternative you can use for palm devices. Cheers.
  10. Firefox90
    Firefox90 What's a Dremel?
    14 Jul 2005
    There is a Palm alternative called "Palmorb" (Google). It's a free program that emulates a small Matrix Orbital LCD. Nowhere near as versatile, but still something to play with. I just now got mine solidly working with an old Sony Clie after about a year of fiddling with it. I may have to pick up a PPC one day to do this better alternative.
