Scratch Build – Complete ⭐ Pocket Rocket - Turning a quad bike, into a gaming/show system!
Discussion in 'Project Logs' started by MT. Mods, 8 Sep 2017.
  1. MT. Mods
    MT. Mods Case Modder
    6 Apr 2016
    Welcome to my Project logs of 'Pocket Rocket'
    What's the deal ?
    For this project, i'll be transforming a brand new 50cc mini quad bike into a full gaming/show system.
    I'll be removing the engine and replacing it with the motherboard and GPU's
    I'll then replace the exhaust system with reservoirs and tubing.
    There's still some stuff to figure out, but very soon i'll get the quad and figure out all that.
    Special thanks to my wonderful partners
    ASUS Republic Of Gamers UK
    Thermaltake technology inc.
    TeamGroup Global
    Cablemod
    Specs
    Intel core i7 7800X
    ASUS ROG Sytrix X299-XE gaming
    ASUS ROG Strix 1080 OC
    TeamGroup T-Froce Delta R 16GB DDR4
    Cablemod Custom cables (Pro Kit with aluminium Combs)
    Cablemod RGB/W Lighting
    Thermaltake
    Riing Plus 12 RGB Radiator Fan TT Premium Edition
    Toughpower Grand RGB 850W Gold Fully Modular
    2x Pacific T22 Reservoir's
    Pacific P1 Black D5 Pump w/ Silent Kit
    2x Pacific V-GTX 10 Series Transparent (ASUS ROG)
    Pacific W4 Plus CPU Water Block
    Pacific M-Pro G1/4 PETG 12mm Fittings - Black
    Pacific G1/4 PETG Tube 90-Degree - Black
    Pacific G1/4 PETG Tube 45-Degree - Black
    Pacific G1/4 Pressure Equalizer Stop Plug w/ O-Ring - Black
    Pacific G1/4 Female to Male 20mm Extender – Black
    Pacific G1/4 Y Adapter – Black
    Pacific Drain Valve – Black
    Pacific G1/4 Stop Plug w/ O-Ring – Black
    Pacific G1/4 Male to Male 10mm Extender – Black
    x3 V-Tubler PETG Tube 12mm OD 10mm ID 500mm 4 Pack
    Thermaltake Pacific Hard Tube Bending Kit for ID 10mm x OD 12mm Hard Tube
    Thermaltake C1000 Opaque Coolant Black
    Thermaltake Pacific RL360 Radiator
    Photo's!
    So... Here's some photo's of the quad, it's due for delivery on monday, excited to start.
    So the quad measures at 1 meter long, 60cm wide and 60cm tall. (Tons of space!)
    One of the first things i'll be doing is removing the panels from the quad and spraying the underside of them, hate seeing that white.
    ASUS ROG UK Delivery.
    First up: Strix X299-XE Gaming motherboard
    Strix 1080 OC edition graphics cards
    ASUS ROG HB SLi bridge
    TeamGroup Global T-Force Delta R kits
    Will update more as the final parts arrive, this is to be hopefully completed BEFORE EGX!!
    Insane time frame, but i must try :D
    Thanks for looking.
  2. MT. Mods
    6 Apr 2016
    Update 1:
    Quad bike has arrived, and put together.
    Currently deciding on where components should go.
    Will be removing the engine a little later tonight, when the kid goes to bed :)
    Thanks for checking out my logs
    -Craig
    AleksandarK likes this.
  3. Cheapskate
    13 May 2007
    Well, you screwed up now. Your girl will wake up in the morning to find you took her new bike apart. You might need to buy a 2nd one.
  4. MT. Mods
    6 Apr 2016
    Hahaha, she's off it now :p
    time to get some work done.
    After removing the engine, i had space to start working on the motherboard plate.
    So i measured, cut to size, drilled little holes for the standoffs, and then drilled holes in the quad chassis, to secure the tray.
    Got bored waiting for the paint to dry haha
    Once the paint was dry, i screwed it all down, and it's not perfect, but not supposed to be, it's completely hidden :)
    Now that it's fitted, i added the MB, and secured that down.
    Perfect fit, Literally no spare space lol
    Will update more as i go.
    Thanks for looking
    -Craig
  5. MT. Mods
    6 Apr 2016
    Cablemod cables and lights have arrived.
    Already started to train the cables into position.
    Amazing quality and service as always! Thanks guys
    And how they look in the system!
    Also added the logo's from our partners (Looks way better)
    [​IMG] #
    Thanks for looking
    -Craig
  6. MT. Mods
    6 Apr 2016
    While waiting for the Thermaltake goodies, i got to work on some of the details.
    Like this!
    I used to have a motorbike, always kept my helmets, this was an old one, So.. I cleaned it down.
    I then sprayed the whole helmet black, and temporarily fitted 2 6w speakers inside the helmet (Will later affix these properly)
    Video here:
    I personally think the helmet adds so much to the build, Just need to decided exactly where i want to put it, front of the seat or back.
    -Craig
  7. MT. Mods
    6 Apr 2016
    Back to work on the helmet/Sound
    Sprayed the visor black
    And started to cable manage the 3.5mm jack cable and power cable.
    vinyl wrapped the side vents, and cut the project name and my name, stuck on the visor.
    Overall, it adds some really nice aesthetics to the project.
    What do you think ?
    -Craig
  8. MT. Mods
    6 Apr 2016
    Watercooling is almost all here, just waiting for the CPU block now.
    Here's some snaps!
    Fittings
    GPU blocks
    Fans!
    PSU
    PUMP
  9. MT. Mods
    6 Apr 2016
    Reservoirs
    Bending kit (Please note, this ain't no cheap crap barrow kit, this is brushed aluminium with some serious weight)
    So far i've only played around with some stuff and can say this... Holy ****! lol
    The pump looks like it was purposely designed for this quad.
    It fits the build so well.
    Then the twin reservoirs.... Damnn... this wasn't a planned build, meaning i didn't spenmd hours going over design ideas thinking carefully where to put stuff.. everything has gone on instinct and so far it's gone well.
    Some closing images
    thank you Thermaltake for this awesome gear, crazy nice too.
    -Craig
  10. MT. Mods
    6 Apr 2016
    UPDATE!
    CPU block has arrived!
    The Thermaltake Pacific W4 PLUS
    Mighty fine looking too!
    Now we just wait for the radiator, and the quad project will be complete!
    Sorry about the delay in updating, it's been a hellish few weeks, multiple projects in the works.
    Thanks for looking
    -Craig
  11. MT. Mods
    6 Apr 2016
    She's finished! She's mighty! She's running smooth!
    Special thanks to my partners, they have been nothing short of fantastic!
    Video will be upped sometime tonight.
    Got a large b-roll to get through.
    Thanks for looking
    -Craig
  12. MT. Mods
    6 Apr 2016
    Quad will be on show at i62 and i63
    :) Ya'll can get up close and personal :p
