Modding pokia cellphone handset guide?
Discussion in 'Modding' started by fartonmyear, 4 Sep 2004.
  1. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
    i first saw these on shiny shiny
    http://www.pokia.com/
    the guy who makes them sells them on ebay, but i would like to make one of my own. could anyone show me how it would be done, especially the bluetooth ones.
  2. splinter_cell
    splinter_cell What's a Dremel?
    8 Sep 2003
    heh, the bluetooth ones are pretty cool, just standing there talking on the phone with a cord just hanging down. you'd get some strange looks.
  3. fartonmyear
    16 Jul 2004
    i'd be using this in my apartment if i had one, not in public.
  4. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    lol i would love to walk down the road with that
    go around town and talk on it and then shout out he hung up how can he :wallbash: :hehe: :hehe: :hehe: :hehe: every one would look and think i'm mad :p
  5. fartonmyear
    16 Jul 2004
    "hello, you have called the red phone. this phone is for emergencies only."
    i've ordered my seimens headset (they use a freaking different connection) and all i need is a spare phone.
  6. lord nicon21
    29 Sep 2003
    :hehe: :hehe: :hehe: oh that would be good :hip:
  7. calking13
    calking13 What's a Dremel?
    15 Jul 2004
    yeah but is there a way to make them? There probably is, but anyone got any ideas?
  8. lessthanjake
    lessthanjake What's a Dremel?
    24 Jan 2004
    i have just checked a phone handset we have and there are two wires connecting it to the phone unit that plugs into the wall, so i would assume it is as simple as cutting off the handset and attaching a 2.5mm jack (49p from maplin) the correct way around whack a bit of heatshrink around it and you're off
    heh heh 69 dude
  9. Blue Raven
    Blue Raven What's a Dremel?
    25 Sep 2003
    Beware, my experience is only with phones in North America, my advice may not be pertinent to all phone systems.
    Inside a phone headset (the part that plugs into the rest of the phone) there are usually 4 wires, 2 for the speaker and 2 for the microphone. The wire that plugs the phone into the wall has only 2 wires that are connected to anything (sometimes the cord has 4 wires but it only uses 2). To connect a phone handset you your cell, the simplest way would be to get a phone handset from a regular phone, and get a headset for your cell phone. Open up both and find the wires going to the speaker and microphone in your headset and connect those to the wires going to the speaker and microphone in you handset. There might be only 3 wires instead of 4 in your cell phone headset, this means that there is a common wire for boath the speaker and microphone.
    I don’t know if there would be any problems with impedance matching on the speaker and the microphone (maybe someone else might know) but it would be caused by the cell phone wanting to use a different kind of microphone and speaker than the regular phone uses.
    You can’t attach the entire phone unit to the cell phone because it is designed to work entirely differently; it has a dtmf encoder and some sort of amplifier plus circuitry to handle the microphone and speaker. If you attached the entire regular phone to your cell phone, it most likely wouldn’t work at all and it might try to pull enough current from your cell phone that it could break it (the cell phone).
  10. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    how about taking apart a bluetooth headset and fitting it to an old phone. you wouldnt need th cable hanging out the phone then.
    just a thought
  11. Blue Raven
    25 Sep 2003
    That would be realy cool if someone could do that, probably would not be too dificult either. Although people might think you are a bit crazy if they see you talking into an old phone while walking down the street. :hehe:
  12. FuzzyOne
    FuzzyOne
    19 Sep 2002
    No doubt the Chav's will soon be hanging them off there <insert sports brand here> badge holders
  13. slaw
    13 Feb 2003
    or you could try to fit one to a glove. i bet you would get looks then!
  14. davew
    davew What's a Dremel?
    13 Mar 2004
    :D :clap: yeah. Walking down the street talking to your hand haha.
  15. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    or round their necks(never understood having your phone round your neck)
  16. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    thats cool
    i like it
    imagine howmany weard faces youll pull
    lol
    :worried: :eeek: :worried: :eeek: :worried:
    then they ask and they say oooooooooooooooooooooooo :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
  17. dom_
    dom_ --->
    4 Jan 2004
    this is not a guide.... why is it in mod-guides?
  18. Atomic
    Atomic Gerwaff
    6 May 2002
    :read: Well first post anyway...
  19. dom_
    dom_ --->
    4 Jan 2004
    yes which means it should be in the thread to request guides, or modding thread. not mod guides as mod guides is for that, guides. not requests
  20. Atomic
    Atomic Gerwaff
    6 May 2002
    True.
    Report the first post to a mod and ask for it to be moved then :p
